Question about Brother IntelliFax-2820 Laser Fax
Cant change fax number of machine
I can not change fax number of machine that it sends to the people im faxing
  • 313 Answers
GO INTO THE MENU AND YOU ARE LOOKING FOR FAX SET UP IN THERE YOU WILL FIND A SECTIOON TO SET D FAX HEADER AND NUMBER THE HEADER IS THE NAME THAT SHOWS WHO IS SENDING THE FAX IE ..VOLVO TULSA OR WHITE HOUSE!!! YOU ENTER THE FAX NUMBER BY THE DIAL PAD AND PRES IOK TO SAVE
Posted on Jun 26, 2009
    President:
  • 566 Answers
Did you check Customer Support on the company site? The manual for your machine is available there in various languages. Or you can download it from here (English):
http://files.getdropbox.com/u/1322442/ALLSF_UkEngUsr_B.pdf
  • A Soveral Jun 26, 2009
    Check thechapter 2 , page 2 of the manual "Change the Station ID":
    Setting the Station ID
    You should store your name or company
    name and fax number so they print on all fax
    pages you send.
    It is important that you enter the fax number
    in the internationally standardised format, i.e.
    in accordance with the following strict
    sequence:
    ■ The “+” (plus) character (by pressing
    key)
    ■ Your Country Code (e.g. “44” for the
    United Kingdom, “41” for Switzerland)
    ■ Your local area code minus any leading
    “0” (“9” in Spain)
    ■ A space
    ■ Your number on the local exchange, using
    spaces to aid readability as appropriate.
    As an example, if the machine is installed in
    the United Kingdom and the same line is to be
    used for both fax and voice calls, and your
    national telephone number is 0161 444 5555,
    then you must set the fax and telephone
    number parts of your station ID as: +44 161
    444 5555.
    1 Press Menu/Set, 0, 3.
    2 Enter your fax number (up to 20 digits).
    Press Menu/Set.
    3 Enter your telephone number (up to 20
    digits).
    Press Menu/Set.
    (If the telephone number and fax
    number are the same, enter the same
    number again.)
    Note
    ■ You cannot enter a hyphen in the number.
    To enter a space press once between
    numbers.
    ■ The telephone number you enter is only
    used for Cover Page features.
    (See Composing the electronic Cover
    Page
    on page 3-9.)
    4 Use the dial pad to enter your name (up
    to 20 characters).
    (See Entering Text on page B-10).
    Press Menu/Set.
    5 Press Stop/Exit.
    Note
    If the Station ID has already been
    programmed, the LCD will ask you to press 1
    to make a change or 2 to exit without
    changing.
I havent used the fax machine in quite sometime<<< i must be doing something wrong... im able to receive faxs but cannot send them, im sure im prolly doing something wrong can u give...
Hey!!The best and fastest way is to put in your documents in the ADF(automatic Document Feeder)Put the machine on fax,Dail your fax number and press the BLACK start button.Good Luck!!
Nov 05, 2010 | Canon MX310 Office All-In-One Printer
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
TRYING TO SEND A FAX IM NOT SURE HOW TO OR WHAT
dial the fax number .. when some one answer ask for a fax tone... then press the send button..
some fax machine when you call the number it automatic give you fax tone ,, after that press the send button..
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Entering my own phone number to a fax machine
press help key then print your setting phone no or change
Jun 28, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
I have brother all in one 420cn. Can send fax but cant recive fax
There are no digital fax machines. You need an analog phone line for your machine to work reliably.
Feb 25, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Apr 18, 2007 | Muratec F360 Plain Paper Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
488 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
