Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Can't see Network Icons in system tray, how do i fix this?
I have Windows Vista x64, and about a week ago the icon for connecting to wireless networks, and LAN info icon disappeared. I've tried right clicking on the system tray and going to the "Customize Notification Icons" area but it is not listed in there either, how do i get these icons back on my system tray?
  • 1 more comment
  • Saraphim Jun 26, 2009
    I tried efs_perpends solution, and it took off all of my hidden icons, and took them out of the "Customize Notification Icons" area. I'm looking all over the Network Connections properties and I cannot find any check box, or option that pertain to the icons...
  • Saraphim Jun 30, 2009
    efs_perpends: Tried both ways posted on your solution, and didn't work, as for the microsoft instructions, i tried doing it myself and letting it fix it for me...no luck
  • Saraphim Jul 04, 2009
    I'm still working on 2 suggestions, I'll let everyone know which ones i've tried, and if the others work very soon
    Thanks,
    Jonathan
  • 428 Answers
Just go to network connections. Right click on each connection and go to properties, And then select the check box which is related to displayin it on the task bar. That will sole ur problem. If it does, pls rate the answer. Thanks. Good Luck
Posted on Jun 26, 2009
  • 3 more comments
  • Tharinda
    Tharinda Jun 27, 2009
    mmm seems not working as I see. Microsoft doesn't take this in to there account and ignores it. what you have to do is...
    Open the local group policy editor.
    In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar.
    Go to the User configurations and drop the Admin templates.
    Click on Task bar and the Start Menu
    Go to "Remove networking Icon" and first disable it.
    Then Apply
    Then again Enable it.
    Then Apply.
    Then it should come there. No need to do any other additional stuff.
    If it doesn't come, please restart.
    If nothing works do this
    Get the RUN box and type regedit and navigate to
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    First do this.
    In the right pane of Explorer, right click on a empty area and click on New and DWORD (32-bit) Value and type HideSCANetwork and press Enter.
    Duble click the value and enter 1
    Then do OK and restart the machine.
    Then
    go to the same registry key which u have created and delete it.
    Check whether the icon comes back.
    If it doesn't, reboot and see.
    Check here also...
    1. Click Start, click Control Panel, and then click Additional Options (You can also right-click the Taskbar, choose Properties, and then click the Notification Area tab).
    2. In the left pane, click Appearance and Personalization.
    3. Click Taskbar and Start Menu.
    4. Click the Notification Area tab.
    Check or un-check the Network check box
    Click Apply and OK to make the changes
    Good Luck.
  • Tharinda
    Tharinda Jun 30, 2009
    This behavior can occur because of one or more of the following reasons:
    • The Plug and Play service is not running, causing the Local Area Connection icon to not be displayed.
    • The Remote Procedure Call (RPC) service is not running, causing the Make New Connection icon to not be displayed.
    • You
      used the Dcomcnfg.exe tool to change DCOM default settings, causing the
      error message listed earlier in this article to be displayed.
    • One of the following network dlls is not properly registered.
      • Netcfgx.dll
      • Netman.dll
      • Netshell.dll
    • The Network Connections service is disabled or is not started, causing the Local Area Connection icon to not be displayed.
    Start the Plug and Play Service
    loadTOCNode(2, 'resolution');
    To resolve this behavior:
    1. Click Start, point to Programs, point to Administrative Tools, and then click Computer Management.
    2. Double-click Services and Applications, click Services, and then double-click Plug and Play.
    3. In the Startup type dialog box, click Automatic, click OK, and then restart your computer.
      NOTE: If the Local Area Connection
      icon is still missing, press F5 several times to refresh the screen.
      Also, you may try restarting your computer in Safe Mode with Networking.
    Back to the top
    Start the RPC Service
    2. Double-click Services and Applications, click Services, and then double-click Remote Procedure Call (RPC).
      NOTE: If the RPC Service is disabled, you may need to use the Recovery Console.
      For additional information about starting and using Recovery Console, click the article number below
      to view the article in the Microsoft Knowledge Base:
      229716
      http://support.microsoft.com/kb/229716/E...
      Description of the Windows 2000 Recovery Console
    4. In Recovery Console, run Enable RPCSS Service_Auto_Start, and then restart your computer.
      NOTE: If the Make New Connection
    Back to the top
    Reset Default DCOM Permissions
    To work around this problem:
    1. Click Start, click Run, type dcomcnfg, and then click OK.
    2. On the Default Properties tab, click any setting other than Anonymous in the Default Impersonation Level box. The default setting is Identify.
    Register the Following Dlls
    1. Click Start, click Run, and then type cmd.exe on the Open line.
    2. Type the following lines, and then press ENTER after you type each line:
      regsvr32 netshell.dll
      regsvr32 netcfgx.dll
      regsvr32 netman.dll
    3. Restart the computer.
    Try this. And make sure You don't have any viruses. Did u do a System Restore???
  • Tharinda
    Did u open any mails recently. Like saying greetings or I love U or similar thing???
  • Tharinda
    U can connect to the net right???
  • Tharinda
    Go to task manager and check network connection devices.
    In there choose action and select "Show non-Plug and Play devices" and check there also.
    Thanks
    President:
  • Microsoft Master
  • 1,996 Answers
It sounds like you've already worked through the basics...I'll assume you've restarted the system and given it time to load completely...
Please see this article, and this link includes a "reset" registry patch if you're not comfortable messing around there manually. If you want an exhaustive recapitulation of the search for a solution to this error, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
  • 1 more comment
  • efs_perpends
    efs_perpends Jun 26, 2009
    You followed the instructions in the MS knowledgebase article, or ran the registry patch?
  • efs_perpends
    Did you reboot after the fix?
    Here's a quick fix that's virtually the same, but has pretty pictures, and you don't have to restart explorer.
  • efs_perpends
    efs_perpends Jul 01, 2009
    Ok, well it sounds like somehow you've corrupted your system files. This could be the result of malware, or it could be some other cause. Have you been using a registry cleaner, or possibly disabled some services in an attempt to speed up your system? Let's do some checking and possibly cleanup. After each bulleted step below, reboot and check for icons.
    • First, follow these instructions and make sure you have Network Connections, Network List Service, Network Location Awareness, and Network Store Interface Service set to Started and Automatic.
    • Then follow Method 2 in this article to modify the Local Group Policy Editor to enable the icons.
    • I would like you to run MBAM to scan for malware. Here's a link to guide you through the malware scan. Follow the first 4 steps outlined there.
    • Then run chkdsk to check your hard drive for errors. Here's a tutorial to guide you through it.
    At this point report back with the results and success or failure, and we'll take it from there....
Network sharing center won't stay open
just been fixing a window vista laptop with problems
Microsoft stopped supporting windows vista years ago
no updates or upgrades
you are at base service pack one
and computer should have been updated to service pack 3 years ago
from service pack 3 a windows 10 upgrade is possible
try an ethernet or usb wifi connection .
.see if the computer will run the way you want it
any windows vista computer is a x32 bit system
with upgrades can run x64
x86 is the current
if you are running anything higher than 32 or x64 software the computer will be slow sometimes freeze or shut down
vista came out same time as and dial up internet
and early broad band
vista can run office 95 but windows 2000 is stable
May 29, 2016 | Microsoft Windows Vista Home Premium with...
On windows vista some desktop icons have a security shield on right side of icon. how do you remove shield and not lose the security?
The icons having Shield icon associated with it means that they need administrator privileges every time they run. Not any kind of security as you think, this thing simply says that they should be run from any administrator's account or other account with administrator password.
Hope this helps, Mrityunjay.
Jun 20, 2012 | Microsoft Windows Vista Home Premium...
Jun 20, 2012 | Microsoft Windows Vista Home Basic Edition
I thought that once I installed the Netgear I would have an icon in my system tray showing the strength of the available wireless connection. My computer is running Windows XP. How do I get that icon in...
On each computer that has a wireless connection to the internet through your router you can enable the status icons as follows:
Click on Start and Control Panel.
Verify that Control Panel is in the "Classic Mode"
Double click on "Network Connections"
Right click on your Wireless Network Connection
Click on Properties
At the bottom of the "general Tab" in the Wireless Networks dialog box, place check marks in:
"Show icon in notification are when connected"
"Notify me when this connection has limited or no capability"
Then Click on OK and exit Control Panel.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jan 29, 2011 | NetGear WGR614 Wireless Router
No puedo intalarlo
The Zero Configuration Utility built into Windows XP may vary depending on if you have installed Service Pack 1 or not.
Download Service Pack 1 here.
Without Service Pack 1
Step 1 Right-click on the two computer monitor icons in the system tray and select View Available Wireless Networks.
Step 2 Highlight your wireless network which is the SSID of your wireless network (if you are connecting to a D-Link router or access point it will be default) and click Connect.
Step 3 If you do not see your wireless network in the available networks box click on the Advanced button. Select Add and type in the SSID of your router or access point, uncheck this computer is connected in and ad-hoc peer-to-peer network, and then click OK.
With Service Pack 1
Please read here regarding Service Pack 1 and disabling the SSID Broadcast.
Step 2 Uncheck the Allow me to connect to this wireless network even though it is not secure box. Highlight your wireless network (if you are connecting to a D-Link router or access point it will be default), and click Connect.
How Do I enable Encryption using the Zero Configuration wireless utility?
Jan 18, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
How do i set up my hp laptop to wifi
Please Understand wireless network settings and setup:
Wireless networks depend on special-purpose radio receivers and transmitters that substitute the exchange of messages over the air for the exchange of messages that occurs over wired connections on conventional networks. When you power on your PC, Windows Vista automatically searches for available wireless networks.
The network icon in the system tray, shown in Figure 1, enables you to view a list of local networks that Windows Vista detects. Notice that the network icon in this figure is marked with a red X, which indicates no network connection is currently established.
Figure 1: A red X indicates no network connection is active.
When you click this icon, a window opens indicating you're not connected to a wireless network, as shown in Figure 2.
hpsmb_laptoppcwireless-fg02.jpg Figure 2: The detail window for the network icon provides a link to create a network connection. The window also includes two hyperlinks: Connect to a network and Network and Sharing Center. Click the Connect to a network link to open the Connect to a network window, shown in Figure 3.
hpsmb_laptoppcwireless-fg03.jpg Figure 3: Connect to a network window.
Nov 10, 2010 | Computers & Internet
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Icons disappeared from notification tray windows vista
Try to do system restore first, restore to the point where everything is working fine.
Oct 29, 2008 | Computers & Internet
Can't connect to home hub
first, check if your networ adapter is installed properly by opening your device manager. if it is there and does not appear with any marks or splats like a question mark or exclamation point, you can close that window, check if wireless zero config (if you have WinXP) or wireless auto config (if you have WinVista) in Start> Run> Services.msc (XP) or Start>click on search field and type in Services.msc and right-click on that item and choose either Start OR Restart. close that window . (on WinXP) open network connections in control panel, right click on Wireless Network Connections>Properties>click on Wireless Connections tab, place check mark on Use Windows to Configure Wireless, click on OK, that will close that window. then right-click again on the Wireless Network Connection and choose View Available Wireless Network, your network should be there now. on vista, just simply look for the "two computer" icons in the system tray at the bottom right near the time, right-click on that and choose Connect to a Network, it should be able to find your network from there.
Aug 21, 2008 | Computers & Internet
IT DOESNT WORK OUT
Sounds like your wireless is disabled.
If your using windows xp, check the following.
Go to your start menu
go to your control panel (might be under settings, might not.)
from control panel, if it says "Choose a Category" click switch to classic view.
open your Network Connections Icon.
If "Wireless Network Connection" is grayed out, right click it and choose, "Enable."
In Windows Vista
Go to the bottom right hand corner of your screen to the icons.
Right click on the double monitors (network connection)
Select Network and Sharing Center
Click on Open Network Connections
If "Wireless Network Connections:" is grayed out, right click it and choose, "Enable."
If it is enabled, and you already have wireless built in to your laptop, then it's possible the wrong wireless card is enabled. If this is the case, when you open your network connections, you will have two Wireless Network Connection Icons.
A Wireless Network Connection, and a Wireless Network Connection 2. Make sure 2 is enabled, and the first one without a number is disabled.
Let me know if this helps.
Mar 17, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
463 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
