Question about Kicker KX500.2 Car Audio Amplifier
Hi how do i wire up my vibe speakers to my vibe sub
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
U dont want to wire ur speakers to the subs, either get a 4 channel amp and wire them into it or to ur deck directly.the reason u dont want to that cause ull blew up ur speakers
Posted on Jun 29, 2009
I have a lanzar vibe pro VBP251 2200 watts and two 12" kicker comp subs. What do I set the amp on
You need to figure out what ohm capacity is of the amp and the speakers. It then comes down to wiring.
Mar 02, 2015 | Kicker Car Audio & Video
VIBE OPTISOUND line out pc
Hi. A model number and the speaker models will help.
Sounds like you need to go from the green 3.5 mm jack to the two phone sockets marked "input" on the sub. White left, Red right.
"output" RCA sockets look to go to your speakers but without model numbers I can't see if they'd need to be powered or not.
Jan 21, 2018 | Audio Players & Recorders
How to wire a single 4 ohm sub to a lanzar vibe 220 amp
Simply connect the sub to the connections marked bridged on the amplifier, It will be the + on one speaker output and the - on the other.
Mar 11, 2012 | Car Audio & Video
I bought i vibe cbr 10 5 months ago and now when its playing it keeps chiping in and out any suggestions as to why thats happening
check the wiring of your power amp that driver your sub woofer, use #4 wire for better performance.
Mar 03, 2010 | Vibe CBR10 Car Subwoofer
The woofer wont turn off
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Nov 19, 2009 | Vibe CBR10 Car Subwoofer
I have a 2channell FE-402 fusion amp,with a fusion sub,and a set of vibe k-series 69's that have a max power of 525 watts. I tryed wiring the sub with the speakers and the speakers sound fine but the sub...
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Jun 06, 2009 | Kicker KX500.2 Car Audio Amplifier
Car Speakers
YOUR POWER WIRE IS NOT STRONG ENOUGH TO HANDLE THE POWER. GET A BIGGER POWER WIRE AND SEE IF THAT HELPS
Jun 30, 2008 | Car Audio & Video
Hooking up a sub woofer
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
take a look there and it should give you everything you need and show you the different options for the different ohm loads. Remember... don't go below 4 ohms on those. Above is ok, below is not.
Jan 10, 2008 | Dual XINBP-210 Car Subwoofer
Vibe cbr1 subwoofer
Might not be eathed properly. Check the earth on the battery as well. Theres more juice goin through there now so it might need a bigger earth or ground.
Jan 08, 2008 | Vibe CBR10 Car Subwoofer
Kicker KX500.2 Car Audio Amplifier Logo
97 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
