Question about Motorola Mobility RAZR V3i Cellular Phone
I need to know how to delete numbers i have dialed
  • 109 Answers
Go to menu, then go to recent calls, scroll down to dialed, it will show a list, hit options, scroll down to delete or delete all then hit yes!!
Posted on Jun 26, 2009
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
How do I clear all e-mail destinations, when I go to fax I pressed clear al and it doesn't work?? I also do not know how to send a fax, I have the phone line connected but it comes back tx failure???
FIrstly, sending a fax : Make sure you have the telephone cable plugged into the correct socket in the back of the copier. There should be one for "LINE" and another for "PHONE" - make sure you are plugged into LINE. On the display panel go into fax mode (press the fax button) and then press the "monitor" key....you should hear a dial tone...this means your fax line is working. You should be able to just dial the number you want and press the start button..... unless you need to dial a 9 to access an outside line - dial that first. make sure the number you are dialing is valid.
To clear/delete email addresses : I assume you have email addresses setup in the address book and want to delete them?
Press "user functions" on the control panel and press "address" then press "address book" button. highlight the address you want to delete and press delete - then confirm deletion....and its gone!
Jan 21, 2010 | Toshiba e-STUDIO 352 Black and White...
Modifying group dial lists
You cannot edit groups, you must delete and recreate.
Jan 09, 2009 | Brother IntelliFAX 5750e Laser Fax
Cannot delete old quick dial numbers
quick dial numbers cannot be deleted.you just have to make sure you print first the auto dial list for you to know where it is located.go to that location,enter zeros and then menu/set to save the number as a zero
Nov 05, 2008 | Brother IntelliFax-2820 Laser Fax
Fax not being sent
Somehow, a group dial # has been set. Here is how to delete it:
NOTE: Group Dial Numbers are entered using the One-Touch keypad on the left hand side of the WorkCentre. To change a Speed Dial that is within a Group Dial, the Group must be deleted first.
  1. Press the [Menu] button.
  2. On the left hand side of the Control Panel press the One-Touch [12] button.
  3. The LCD Display will read 'Select One-Touch for Group [01-20]'.
  4. Press the One-Touch key to be used for the Group Dial.
  5. One of two displays will appear:
    • If the Group Dial number has not been used:
      1. The LCD Display will read 'Group No: ### 1. YES 2. NO'.
      2. Using the Dialing Keypad press [1] to accept or
      3. Press [2] to return to step four.
      4. The LCD Display will read 'Enter One-Touch / Speed Dial> ##'.
      5. Continue with step 6.
    • If the Group Dial number has been used:
      1. The LCD Display will read 'Group ## Used 1: Renew 2: Other'.
      2. Using the Dialing Keypad press [1] to 'Renew'. This will cancel the Speed Dial or Group Dial entry and the Group Dial will be deleted.
      3. Press [2] to keep the current entry and select another Group Dial
      4. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Apr 26, 2008 | Xerox WorkCentre 470CX InkJet Printer
Deleted my voicemail key
Use the super key again to program a speed dial key that dials the voicemails number. Instead of selecting 'clear' slect "change" and type in the number. To find the number of the voicemail, go to another phone and press their voicemail key and watch the display. It may briefly display the voicemial group number. You also can dial the voicemail number without the use of a button on your phone. But, you have to know the voicemail group number to dail it. Sorry i dont know the number to tell you, it could be anything that the installer decided to make it.
Sep 27, 2007 | Mitel Superset 4025 Corded Phone...
PANASONIC KX-A144EXS
druk middelste knop ,nr verschijnt !
druk ronde knop rechts,
druk ronde knop naar beneden tot WISSEN verchijnt en druk dan ronde knop rechts en kl is kees
Sep 06, 2007 | Panasonic KX-T7730 Corded Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
