Ice is building up in the tube where ice is dispensed. It appears that the small plastic door that keeps outside air from getting in the freezer is not staying closed .
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay...
(More)
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay blinking, then temperature display went blank and showed "HRS", now just blank and no cooling.
My ice dispenser keeps freezing up and clogging. It appears the flapper that closes after ice is...
(More)
My ice dispenser keeps freezing up and clogging. It appears the flapper that closes after ice is dispensed does close tightly and allows warmer air and humidity to enter to enter the freezer. Can the tension spring on the flapper be adjusted or does it need to be replaced?
the fridge and freezer are not working.. the light comes on and you can hear air blowing in the...
(More)
the fridge and freezer are not working.. the light comes on and you can hear air blowing in the freezer, but it is somewhat warm air.
