Question about Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500
Did Acer Aspire 5500 got recovery system?something like go back to factory setting
  • 128 Answers
Re: Acer Aspire 5500
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Posted on Feb 02, 2008
  • 2,961 Answers
No, with Acer notebooks you are prompted to do a system back up to dvd as soon as you have all the system up and running
Posted on Nov 06, 2007
0 characters
3 Points
How do i do a system recovery without a disk
Try This . When the System CD and Recovery CD are not available, you can create them by
using this feature.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery window, select Recovery settings and click Next.
5 In the Recovery settings window, select Burn image to disk and click Next.
6 In the Burn image to disk window, select 01. Factory default image and
click Next.
7 Follow the instructions on screen to complete the process.
Jun 24, 2011 | Acer Aspire 5500 5570-2609 Laptop
How do i reset my laptop back to factory settings
The disc that you should have received with the laptop should give you this option. Just put it in and reboot and it will bring you to a menu with a few different recovery options to choose from.
Feb 28, 2011 | Acer Aspire 5500 5570-2609 Laptop
I need to reset my acer aspire 5520 to factory settings without recovery discs
There is a recovery console on your HDD (Hard Disk Drive) this is a hidden partition on your HDD. If you power on your laptop and hold the ALT key and keep tapping the F10 key while it posts to the acer logo screen it will goto a black screen with a flashing cursor on the top left then stop tapping F10 and remove your finger from the ALT key, you will then see windows loading files. This will take you to the recovery console and from there you can select restore laptop to factory defaults or restore laptop retaining user data.
Hope this helps
Feb 22, 2011 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 7730 running vista BSOD error startuprepairv2
At this point I would suggest to try a full system restore as the sytem files might be corrupted. You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 26, 2010 | Acer Aspire 5500 5570-2609 Laptop
How to restore factory recovery system
If you still can boot it in windows, follow this:
Step 1: Click “Start” menu.
Step 2: Click “Programs.”
Step 3: Click “Acer Recovery Management.”
Step 4: Click the “Restore” button on the bottom of the dialog box that opens.
Step 5: Click “Restore System to Factory Default.”
Step 6: Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7: Click “Start” to restore the computer to the default factory settings.
If you can not boot to windows, follow this:
1. Restart the laptop
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Follow the on-screen instructions to perform system recovery
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Do not have recovery cd but want to restore factory settings.
you need to open erecovery and do a factory default restore ,and you wont need the disk for the recovery function either,thats as long as you have erecovery installed on your machine already
Apr 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
How do I restore factory settings on a acer laptop
use recovery disk or go to the acer website and you can order a recovery disk.
Oct 02, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire one
Hi there..
I had the same problem, but i did not geth any help..So i did find the solution by my own... Maybe i can help you...
Because they tell us to open some windows programs, but i could not even open my windows, so how i can make a recovery???
So, my friend, if you want to recovery your laptop, you shuld start him, and when he start, you press simultaneously Alt and F10. Then you can make your recovery. And look in the BIOS that is enabled Disc to disc recovery
Nov 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
522 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
