Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My whirlpool top loader will not spin or drain. i just replaced the lid switch and machine still not working.  it agitates fine.
  • antjuj Jun 26, 2009
    I found that if I push the timer in and pulling it back out that it will spin and drain. How do i replace the timer?
    Top Expert:
  • Whirlpool Master
  • 80,637 Answers
THE ONLY THING THAT WILL CAUSE THIS IS A FAILED TUB SPIN MOTOR DRIVE COUPLER., LIFT THE MACHINE UP AND ONTO ITS SIDE U MAY FIND BROKEN PARTS UNDER IT. GO TO THIS WEB SITE TO SEE PART, IT IS CALLED THE DRIVE COUPLER.
http://www.repairclinic.com/Appliance-Parts?s=t-LSQ9549L-%3d%3dd622414c203
Posted on Jun 26, 2009
    Sergeant:
    Champion:
  • 233 Answers
I had the same problem last month.
The thing is that u need to change the thermostat.
You have to bring in those workers to do it 4 u
cuz i dont think u can do it urself.
Good Luck!!!
How do I fix a top loading washing machine that isn't spinning, agitating or draining?
if this is a top loader put a pencil into the lid switch opening if the machine spins and drains when the timer knob says it should the tab on the lid or the lid switch has failed...replace the switch or the tab that goes into the lid switch opening
Jan 26, 2016 | Amana Washing Machines
Hi Dennis! I have a whirlpool ultimate care II washing machine. It agitates, but will not drain or spin. any suggestions?
Check your lid switch, you should hear a click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 17, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is not draining or spinning. It fills & agitates. whirlpool LLR8245DQ0 . i LOWERED THE DRAIN HOSE AND DRAINED IT BUT IT STILL DIDN'T SPIN
It may be the wire from pressure switch is either not receiving power through the switch or it may be broken? If that is ok then check timer.
Jul 29, 2009 | Washing Machines
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
44 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
