Question about Kenmore Oasis HE 27082 Top Load Washer
Any idea how to reset it or at leat open the lid?
It was washing propertly and all the suden just stop, no power, control panel dead, lid is locked and no way to turn it on. Any idea how to reset it or at leat open the lid?
  • 15,935 Answers
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Hi, I put a wash on but it stopped have way through and the machine is locked. I cant remove my washing. Any know how to open it. There is an 01E Error message.
"1E" persists in washer display------ Lid lock failure----- Replace lid lock switch or control board.
This on a Maytag but sometimes you only have to reset the board, you just need to know the button combination and for that you need the brand and model number to find your manual, if you have it just find the sequence for resetting the board
Apr 29, 2016 | Washing Machines
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Lost power to washing machine
When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
Jan 04, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Washer is "dead." Was stopped after fill up, and now no power.
Hi, I would check the lid switch first. Remove the two screws that hold the control panel to the cabinet and let it rest on the hinges. Locate the lid switch connection and either test it for continuity or use an insolates wire and jump the switch by inserting the wire into the gray and brown wires. Turn the washer on and see if it works.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
Jun 20, 2009 | Maytag LAT3600A Top Load Washer
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Top drawer stuck, gaskets rubbing, no power to controls
I see the question is posted in the DD603 section, so I am not sure if I am giving the proper advice. Are you sure this is a 602/601 series? A DD603 model has lid actuator motors, not the inflatable style seal. It sounds like the lid motors are in the DOWN position. Since the machine is "dead" what may have happened is the heater plate opened up (the heater plate is a dropping resistor inline with the machine's controller) when the machine was in use and that stopped everything dead.
Double-check your model number so we know what style of lid your machine has, The difference is huge between models.
Dec 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer lid will not open after cycle
suspect bad lid latch there is usually a 4-6 delay after washer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
May 22, 2008 | Kenmore 98702 Stacked Washer/Dryer
Ariston washer
is this a new washer. if so remove shiping bolts from bottom or back.
Feb 15, 2008 | Washing Machines
Kenmore Oasis - Lid Locked Shut and No Power
take your outlet pipe and place into a bucket so that it is low to the ground if water comes out then it could be that your pump is faulty when the water has all drained away the pressure switch will reset itself and the lid will now open if no water comes out un-clamp your outlet pipe from your pump if then water comes out then your pipe will be blocked m8
Aug 14, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing machine dead...
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise: 1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely. 2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit. 3) Unplug the washer and check the power cord. If necessary, replace the cord. 4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore Oasis HE 27082 Top Load Washer Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
