My central air conditioner is not working properly. It doesn't get cold. All it does is cool air comes out and the house doesn't get cold. What do I do?
  • ddg_10 Jun 27, 2009
    the temp in the house is at 28 celcius. Air is coming out but it's not cold air. It's more like room temp air or air you get from a fan.
  • ddg_10 Jun 28, 2009
    Actually, it's on the side of the house. It's a York central unit.
  • 146 Answers
Well how cool is cool check temp at one of the register should be around 54 degrees. if so you other problems
Posted on Jun 26, 2009
  • paul sandouk
    paul sandouk Jun 28, 2009
    well i do not know is it split system or package unite is on the roof or on the ground? . you can check the fuse. or if no idea what i am taking about it time to call a Pro!
2 Suggested Answers
  • 74 Answers
SOURCE: central air conditioner doesn't cool
A central air conditioner that runs but doesn't cool may just need to be cleaned. Plan to do this on a relatively warm day. First look for your owner's manual and, if you can find it, follow its instructions. If you can't find it, request one from the manufacturer (see Resources). To clean the filter, remove it from the furnace or air handler (it?s usually located inside or very near the air inlet side). Replace a disposable filter or clean a reusable filter according to the manufacturer?s directions. 1) Before you begin, check the thermostat to make sure it is set to "cool" rather than "heat." Then turn off the power to the unit; there is normally a shut-off or disconnect panel on the house wall next to the outdoor compressor. Otherwise, shut off the air conditioner's 240-volt circuit at the main electrical panel. 2) Rake leaves and debris away from the outdoor condenser. 3) Remove any protective grille or cover from the condenser's fins. 4) Use a soft brush to clean dirt and debris from the fins, then vacuum them with a brush attachment (be careful not to bend or damage them). If you accidentally bend fins, you can buy a comb made for straightening them at an appliance parts store. 5) Unscrew and lift the top grille off the unit, if possible. If the fan is attached to the grille, be careful not to pull any wires loose. 6) From inside the unit, hose out the fins (protect the wiring and motor with plastic). If your owner's manual calls for lubricating the motor, do that now--don't over-lubricate. 7) Then reassemble the unit. 8) To test it, turn the power on and set the thermostat to turn the unit on. Let it run for a few minutes, then feel the two pipes that connect to the condenser unit (slide any insulation back). One should feel warm, the other cool. Otherwise, call an air conditioning technician--the refrigerant may need to be recharged. NOTE: Avoid straining an air conditioner's compressor by waiting at least five minutes between turning it off at the thermostat and turning it back on. Air conditioner or heat pump still giving you trouble? To Home Problem Solver Main Page Copyright. All rights reserved. Interested in licensing this DIY Content? Related terms: what to do if, how to fix, troubleshooting, DIY, air conditioner doesn't cool, air conditioner too warm, warm air from air conditioner, air conditioner not cold enough, how to clean air conditioner, cleaning air conditioner, air conditioner cleaning
Posted on Jan 18, 2006
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
I have the York Outdoor Split System Air Conditioner- Model # h4de024S06A, Installed in my home on june 12, 2004. We had no problems at all until last night when we noticed that the Furnace of the Fan is...
I think you may have 2 problems. Thje outdoor fan not coming on would cause the compressor to either go out on high discharge pressure or internal overload. Either the fan is bad or the capacitor is bad or both, which can be replaced.
The second problem is either the unit froze up on you and for the short time that it will cool before it quits. You may want to make sure you cool speed for your indoor unit is set to hi cool speed which is usually black
Jul 06, 2010 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
My Trane air conditioner is not blowing cold air
there could be a few things low on freon will cause the coil to ice up and no air can get through,breaker or switch to the blower unit in the house is off belt broke or the moter let go
Jul 05, 2009 | Ruud Central System Air Conditioner
Central air/heat pump not putting out cold air
I have some things for you to check. If you look at the outside unit the lines going into the house. Are they frozen? Have you had any yard work done, the reason I ask is they could have accidentally cut or pulled out the thermostat wires to the ac unit. Also, inside check for the same thing, frozen lines. Also, you may want to check the drain coming from the inside unit, it may be clogged.
Jun 22, 2009 | Heating & Cooling
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
462 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
