Question about Garmin nuvi 255W GPS Receiver
Need to know how to charge garmin nuvi 255w using home wall charger.
  • Garmin Expert
  • 343 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Posted on Feb 06, 2010
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Just purchased a Garmin 255W. Works fine if not attached to the car charger. Attached unit to the charge and normal navigation screen disappears. Shouldn't a person be able to drive/navigate and charge...
Hi sudavis70,
yes, you should be able to use your 255w while driving...if its going to the garmin screen ( or the screen with the computer icon) when plugged in to the car charger, then the car charger is probably either bad or not compatible with your unit..if its the original charger, i would buy another one thats made for a garmin.
the only time you shouldn't be able to use your 255w, is when its hooked to your computer.
i fix these and many other gps daily so when considering my advice , please understand i do not google my solutions.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Nov 04, 2010 | Garmin nuvi 255W GPS Receiver
Other than using the car, how can I charge my garmin nuvi 255W
You can charge it by connecting it to your computer with a usb cable. This takes about 8 hours to charge. Or you can buy a mains charger which takes around 4 hours to charge.
Sep 06, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 255w won't start up. tries loading maps and then goes in a continuous circle. acts if not charging. tried reseting and charging with wall charger and car charger
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
May 25, 2010 | Garmin nuvi 255W GPS Receiver
I received a Garmin Nuvi 255w as a gift back in October 2009. I am a Realtor and use this almost every day. Yesterday I was driving around, and I did have the Garmin charging with the car charger. In the...
The unit should still operate and turn on even with a dead battery when connected to an external power source such as the DC car charger, AC wall charger or USB cable (connected to a PC).
Please try the reset procedure listed here:
http://www.sharc.net/discus/messages/6/313.html?1269314749
- Jim
Mar 26, 2010 | Garmin nuvi 255W GPS Receiver
How long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Jun 30, 2009 | Garmin nuvi 255W GPS Receiver
My new garmin 255w is not charging
I had the same problem. The plug wasn't sitting right in the charger hole.
Jun 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
2,209 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
