Question about Apple MacBook Mac Notebook
My macbook keeps droping signal and bouncing between 1 bar and full signal
    Sergeant:
    Champion:
  • 233 Answers
Could u plz provide more info??
It might be cuz ur signal isnt good.
Posted on Jun 26, 2009
My huawei h881c keep droping server connect how i fix it
Make sure you have at least two bars of signal strength before attempting calls or data transfer. You may have to sit near a window.
You responded that you have 3-4 bars of signal. I suggest you visit your carrier's place of business (AT&T, Verizon, etc.). Demonstrate the problem to the representative there.
Oct 02, 2015 | Huawei Cell Phones
Unable to open iPhoto on mac air
Does it try to open, does the app icon bounce in the bar on the bottom and disappear?
Jun 04, 2012 | Apple MacBook Air
I accidently droped the mp3 player in water and its not comming on the charging bar keeps on going from full to empty rapidly and the buttons are not working.
electronics that have been dropped in water should be taken apart immediately, allowed to try with a fan on them for 2 or so days, reassembled and then attempt to charge. If this doesn't work- sorry, but it's toast.
May 05, 2011 | Health & Beauty
My network signal keeps fluctuating (from one bar signal to full bars, sometime even end at zero bars) compared to other phones around me (which indicates there is a strong signal).
THERE MIGHT BE DUST INSIDE UR PHONE SO GET UR PHONE CLEANED FROM INSIDE AND IF IT PROBLEM IS STILL THERE THEN CHANGE THE SIGNAL IC
Sep 24, 2010 | Cell Phones
Cant get fly wheel off . Droped trans & have fly wheel exposed...6 bolts, And they wont come off.
Soak in penetrating oil and remove bolts using air line. If no access to air tools then use breaker bar with constant pressure (no not bounce)
If no joy then you wheel need to heat the flywheel - if you have to do this replace the rear main seal aswel.
Regards
Lloyd Six
Apr 30, 2010 | 1986 Ford F150 SuperCab
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
LG KS360 Signal in and out and roaming all the time
Mine does the same thing. But that actually is because my house has terrible signal in certain parts... The best thing to do is to make sure that where you do makes call ect. is somewhere with very good reception..
Something like that tho can't really be helped.. I think this phone is just generally terrible for getting a good signal.
Jun 16, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Well, got a new router
have you done into utilities/airport utility? there is a "transmit power" option in there, to check your transmitting settings. try resetting the router
Dec 31, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Call droping
There is no easy solution. Visit your operator service. Hope you got warranty. :)
Sep 11, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Apple MacBook Mac Notebook Logo
47 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
