Question about Homelite Mighty Lite Lawn Trimmer
Have a homelite UT 20573 A, trimmer need a manual
Have a homelite UT 20573 A, trimmer and I need a manual for it, having problems with carb and string head
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
  • 6 Answers
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
  • 508 Answers
SOURCE: Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Posted on Jun 22, 2009
SOURCE: I am looking for a manual for a homelite gas
type in homelitest and ut number on the trimmer and then search google . maybe
Posted on Jul 11, 2009
I took my homelite trimmer apart to replace the clutch, but now can not get the engine housing to go back on, is there a trick to this ? Model ut33600a
Hopefully this will help if not go to homelite.com ordreing parts then select homelite then string trimmer then find your ut 33600a
Jul 15, 2017 | Homelite Garden
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
Homelite y 2500 yardmachine trimmer
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
May 22, 2014 | Homelite Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Bgreen. Need correct part no. for primer bulb for sx135 bandit string trimmer. old one has cracked due to age.
Your SX-135 string trimmer was built by Homeliteand has a model number of UT-20601. That said, your trimmer's primer bulb part number depends on teh type of carburetor it has. If your trimmer has a Walbro carburetor, the primer bulb part no. is 01201. If it has a Zama carburetor (the most likely one) the primer bulb part no. is A01195A.
You can go to the following website to order the part: http://www.homelite.com/service_support/order_parts
Good Luck, hope this helps!
Oct 15, 2009 | Garden
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
534 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
