Question about Curtis-Mathis Televison & Video
What causes lines across the top of the picture on my tv? There's about 7 inches of white horizontal lines
  • 100 Answers
Capacitors in vert.out.
Posted on Jun 28, 2009
Horizontal lines in Samsung led tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 18, 2017 | Samsung Televison & Video
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White horizontal lines at top of picture
Yes, definitely worth fixing. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor (no more than USD4.00 in price) usually gets it working perfectly again. If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 17, 2008 | Toshiba MD24FP1 24 in. TV/DVD Combo
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Televison & Video Logo
137 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
