Line to evaporator iced over
I have a Lennox model C26-51/65FC-1 and the line leaving the outside A/C unit is covered in ice (the outside unit seems to be running fine). The line leads to the evaporator unit inside my house and has the same condensate frozen on the outside of the insulated copper pipe. The evaporator housing is cold to the touch and has water condensing on it. The fan is running and blowing air out all the vents normally but it's not cold air. I've shut the unit off (but left the fan going) to get the ice to melt off the line. Is this a problem with the evaporator? I live in a small town and getting a qualified Lennox repairman has been expensive in the past. Wanted to try and verify the problem and solution before making the call. Thanks in advance!
    Problem Solver:
  • 5 Answers
Yes it probably needs a high limit switch or something else that will turn the compressor off when the pressure gets too high or the temp gets too low. Or compressor could be shot, either way if you are not familiar with it you will need someone to come look at it.
Posted on Jun 26, 2009
  • 334 Answers
I am not exactly sure as to the type of unit you have. If it is a ductless split system (inside unit on the wall, never seen Lennox make one) you could be low on charge, the metering device to drop the refrigerant pressure is in the outdoor unit. If this is a whole house system, you may have a restriction in the outdoor section somewhere. If you look into the unit while it is running, try to find a filterdrier. It is a cylinder soldered into the small line. You can also see exactly where the ice starts, that is where your restriction is. Let me know what you find out.
seth
Ice buildup by evaporator fan down into drain in back of unit. I melted ice using steam and heat, but it has happened 4 times.
Your defrost id not working, you didn;t leave a model so that is all I can tell you now
Mar 26, 2016 | Refrigerators
Water leaking into bottom of freezer
The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campionhttp://www.affordableappliance.com
Mar 23, 2012 | Whirlpool Refrigerators
Is there supposed to have ice on the lines inside the house on the central air cooling unit?
No there is not supposed to be any ice. The bigger tubing may sweat but not ice over. If it is iced over:
1. check your filter
2. refrigerant may be low
3. the evaporator coil may be stopped up with dirt.
If there is ice on the line, more than likely, the evaporator coil (located above or below your indoor unit) is also iced over causing low air flow through your ductwork. The air coming through the vents may be real cold but there may not be much force. This indicates a stopped up or iced over evaporator coil or a dirty filter. Best thing to do is turn the unit off, let it thaw our for a few hours, change the filter while waiting, and try it again. Hope this helps you. stay cool. mark
Jul 10, 2011 | Intertherm Heating & Cooling
I have a Lennox XC13 Air Conditioner. When it is
You more than likely have a refrigerant problem. When the unit is under/over charged, it will freeze up the lines, a-coil, etc. The blower will seem like it's not pushing that much air anymore because of the ice blocking the air flow. Another possibility is the a-coil, which is on the indoor unit, could be dirty and the dirt and grime blocking the air flow can cause the same effect, you have to take the cover off, then take the small cover on the a-coil off, then you will be able to see, but if the air flow is working correctly at first, then slowing down, your problem would be the refrigerant charge. Hope this helps and good luck!
Jul 12, 2010 | Heating & Cooling
The unit is not cooling. have noticed ice on the line in the unit outside.
if one or few pipe may not aproblem may be the thermostat is aet to very low cool anf the fan on low speed or the thermostat is defective also if this icing is growing up means
-1 evaporator need cleaning
- 2 a smll freon leakage
May 04, 2009 | Heating & Cooling
Water is leaking from the ice maker. It is
Are you sure the ice maker is leaking? MOst often it is a blocked drain. The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Mar 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridge autodefrosting but condensation not draining away and evaporating causing a build up of water in bottom of fridge section
Feb 27, 2009 | Miele KFN8762SDED Bottom Freezer...
Leaking water under frig and ice-maker is not hooked up?
Feb 20, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Need to replace evaporator fan GE profile performance TNX model
Unfortunately, the evaporator fan has probably frozen in water trapped in the defrost drain. This seems to be a common problem with these GE bottom freezer models. You can shut it off for 12-14 hours and leave the doors open and it will thaw and drain into the freezer compartment. But you probably have food that you would need to put into another refridgerator to do this. Another option is to take out the bottom liner of the refridgerator to do this - I had a service man do it the first time it happened - he then used hot water and a hair drier to get rid of the ice that was stopping the fan. Unfortunately, it seems once this problem starts happening, it will continue to reoccur and I have not found a long term solution yet
Nov 15, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
