Question about Jl Audio 250/1 Car Audio Amplifier
250/1 powers on but no output
I have a 250/1 jl audio amp, i tested it on two different cars and two different subs, the amp is the problem.
the amp powers on and everything is green but the problem is that the sub is not moving at all, is there a way to fix the sub output on these amps?
i disassembled the amp but found no burn marks, i have no idea what the problem is. i tried my friend's 250/1 it works great on my car.
so any suggestions?
  • 631 Answers
If the amp is not going into protect, the power supply FETs have probably failed. In the corner of the amp near the toriodal transformer, there are 4 FETs against the heatsink. When these fail, the 47 ohm resistors at the base of the transistors often fail. If the resistors are dark, it generally means the FETs have failed. If you disconnect the amp from power and measure the resistance from leg 1 to leg 2 of the power supply FETs, a reading of near 0 ohms indicates the FETs have failed.
Posted on Dec 31, 2007
I have power to my Jensen 400 watt amp. But no
It's possible the output stage(s) of the amp are blown. Check all audio wiring connections to the amp, input and output, to make sure nothing is loose or disconnected. Also, try wiring up a different sub to verify it isn't the sub that's bad.
Aug 28, 2014 | Car Audio & Video
I have a Jl Audio 250/1 mono block amp and the thermal light keeps coming on what could be causing this?
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
Mar 04, 2011 | Jl Audio 250/1 Car Audio Amplifier
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Jl 500/1 no output audio
You can send it to JL Audio and they will fix the output stage you toasted and will also perform any mods or upgrades to bring it up to spec. This will set you back $ 180.00 plus shipping cost to send it to JL. I know it's expensive but you damn near get a whole new amp to rock your world. mark..
Dec 18, 2008 | Jl Audio 500/1 Car Audio Amplifier
I want to know if it is possible to connect two JL Audio 250/1 amps together to power three subwoofers.
I hate to be the barer of bad news but no I do not believe it is possible to do that and you will probably fry both amps if you attempt it.
But you can connect three subs to one of them
Nov 24, 2008 | Jl Audio 250/1 Car Audio Amplifier
My jl Auido 250/1 amp
You may have a bad output on the amplifier. I would recommend taking it to a local electronics repair to have fixed, or visit a local stereo shop - preferably a JL Audio dealer. Visit their website at www.jlaudio.com to find a dealer near you. You can have your amplifier sent in to JL Audio for repair by an authorized dealer and you'll get a warranty on the repair work.
Sep 27, 2008 | Jl Audio 250/1 Car Audio Amplifier
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Apr 09, 2008 | Jl Audio 12W3 Car Subwoofer
Added another amp to system now subs dont hit as hard
This sounds odd, but try putting your subs out of phase from the mains. Just see if it changes anything.
Feb 16, 2008 | Jl Audio 250/1 Car Audio Amplifier
Sub makes loud noise when car is shut off
Does it make noise if the RCAs are unplugged? If not, the RCA shield on your head unit may be burned open.
If the amplifier is set to signal sense, it will take longer for the power light to go off.
Nov 13, 2007 | Jl Audio 250/1 Car Audio Amplifier
Jl Audio 250/1 Car Audio Amplifier Logo
317 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
