Question about HP Compaq FS 7550 17" CRT Monitor
Monitor makes annoying screech noise
When applications are maximized or opened more than half the size of the screen, the monitor emits a high pitched screeching noise which will only go away if you reduce the size of application windows or minimize them entirely.
  • Anonymous Mar 14, 2008
    The monitor only stops making the noise if you switch it off
  • 24 Answers
What you are reporting is a problem in the horizontal section of your CRT monitor. Usually this is from a component that is failing in the Horizontal circuit.
Most CRT monitors use what is called scan rectification to develop the voltages required for the different circuits inside the monitor. This puts a strain on the Horizontal Output circuits that are responsible for not only the voltage to the flyback transformer to allow CRT illumination (40,000 or so volts DC), but some of the flyback secondary power circuits are what runs the rest of the monitor. When the components in the Horizontal output circuit get weak and can no longer support the higher demands of the dependant circuits, the flyback transformer tries to run harder. The more current it tries to draw to continue operating, the louder the whine becomes. Since the flyback operates around 17,000 cycles per second, it is in the audible range. Since you can physically hear it, you can also notice the change as the load demand on it changes.
What happens when you reduce the size of application windows or minimize them entirely is the demand on the power circuits is lessened and the flyback circuit is no longer trying to produce the higher demand that it was with the large application windows.
It is a good bet that it will not be too long before the Horizontal output and/or transformer give out completely and leave you with a dead monitor and a large repair bill.
Since it has not gone completely out yet, I would suggest you consult your local repair shop for an estimate. It may be a simple matter of replacing the high voltage capacitors around the Horizontal output transistor before the other parts in the horizontal circuit are damaged. This would certainly be a less expensive alternative.
If you opt to not get it repaired, new 17 inch LCD flat panel monitors can usually be purchased for around $150 or so.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
(I realize I probably gave you more information than you wanted, but I felt it might make things a bit easier to understand. If not, please forgive the disertation.)
I hope this helps.
Posted on Nov 06, 2007
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
View sonic computer screen was dropped and now when you turn it on the picture comes on and then it emits a high pitched sound and turns off. any suggestions?
Sounds like you may have broke at least one of the lamps . The high pitch sound you are hearing is the high voltage that goes to it .
Feb 05, 2011 | ViewSonic OptiQuest Monitor
SyncMaster 793DF 17" CRT Monitor: monitor makes high pitch noise...
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback.
Normally, it is the cause of the noise.
Warning: High Voltage!! Do at your own risk!!!!!!
Best regards,
May 16, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Turns on then gives a High pitched Screech then shuts down even after totally unplugging it and reconnecting it blinks on then Screeches then turns off rinse repeat
are you talking about just the monitor of the computer as a whole? if you are talking about the computer then, there is something loose inside the case, which is causing the high pitched sound.
Jun 27, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor makes loud screeching vacuum sound; no screen display..?
check to make sure that there arent any magnets near or around it
Apr 13, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Flashing Off
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
Feb 08, 2018 | Samsung SyncMaster 2253BW LCD Monitor
New flat screen monitor humming noise
This could well be your refresh rate. Move your mouse pointer over any blank area of the screen and right click. Highlight and click on properties.Click on the settings tab, then on advanced then on to the monitor tab. You should see a setting for refresh rate eg. 75 Hertz. Change the refresh rate and the noise should disappear.
Jun 30, 2007 | Samsung 920BW (Black) Monitor
High pitch sound being emitted
It could be a harmonic noise caused by dust inside the monitor. If you are qualified (brave enough) to remove the back cover, blow the entire inside of the monitor out with compressed air (carefully) that may help. It could also be the flyback transformer. In that case, you would have to have the transformer replaced (I wouldn't recommend doing it yourself unless you are a TV technican as the CRT can contain a static charge of 14,000-25,000 volts- even when unplugged)
Oct 15, 2006 | Philips SoHo 107T21 (White) 17" CRT...
HP Compaq FS 7550 17" CRT Monitor Logo
231 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
