Question about HP LaserJet 3055 All-In-One Printer
Comm Error 400 and Comm Error 356
Our Fax Activity Log shows numerous Comm Error 400 and Comm Error 356 codes after sending failures. A few faxes go through after multiple attempts.
There is tone on the line when we hook a phone to the "phone" jack on the printer. There does not appear to be a static on the line.
When we checked with some of the recipients that we are repeatedlysending to, they report no other known problems.
keshy
  • 77 Answers
SOURCE: ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Posted on Oct 10, 2008
  • 163 Answers
SOURCE: Fax shows an 'off-hook' status
pleaz check the hook sensor
Posted on Sep 16, 2007
ctf1800
  • 4402 Answers
SOURCE: Fax not answering or receiving
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=391194&rule=44610&lang=en
Visit the HP Support and Drivers Home page .
Posted on Jan 24, 2008
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
SOURCE: comm error 232 & no fax detected when receiving
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Posted on Nov 18, 2008
Why can it only send one page fax?
This is usually caused by interference on the telephone line. Try a different telephone cord to the wall or try connecting it to a different wall jack to narrow down the cause.
Mar 31, 2016 | Brother MFC 8820D All-In-One Laser Printer
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
I can not receive a fax
Hi there, Fax machines are still in common use today despite the widespread adoption of computers along with their multiple communication tools, including e-mail and social networks. Fax problems can include trouble receiving faxes, dialing issues, faxes not printing and poor print quality. Performing periodic maintenance can help with fax problems. Check any visual indicators for trouble. Many fax machines have a display panel and use it for reporting error messages. Often the messages are in plain text and can be understood without referring to the instruction book. Refer to your fax machine'smag-glass_10x10.gif instruction manual for any numeric error codes.
  • Step 2.Replace the cables. In particular, replace the telephone line cable that runs from the wall to the fax machine. The plugs can become lame, and the wire itself can break inside, providing no visual indication it's broken.
  • Jul 31, 2010 | Sharp UX-B750 Inkjet Fax
    I keep getting comm error 242 when people are faxing to me
    The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
    Apr 28, 2010 | HP LaserJet 3050 Printer
    I have hp laserjet 3050 and i not able to receive fax
    Hello Rupesh,
    Following is the description for Error 232
    A communication failure (comm error) has occurred between the two machines. OR The user at the remote machine may have pressed CANCEL. OR The power at the remote machine has been interrupted, or deliberately turned off, causing the fax session to be interrupted
    1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
    2. If the error persists, and error correction is in use for the fax session, disable ECM
    Disable V.34 on local machine V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON.
    Follow the steps below to disable V.34 setting.
    1. Press Menu/Enter.
    2. Press the < or > buttons to select Fax Setup, then press Menu/Enter.
    3. Press the < or > buttons to select All Faxes, then press Menu/Enter.
    4. Press the < or > buttons to select V.34, then press Menu/Enter.
    5. Press the < or > buttons to select OFF, then press Menu/Enter to save the selection.
    top
    Disable or Enable the ECM
    4. Press the < or > buttons to select ECM, then press Menu/Enter.
    5. Press the < or > buttons to select OFF or ON, then press Menu/Enter to save the selection.
      NOTE: The default setting for ECM is ON.
    Dec 20, 2008 | HP LaserJet 3050 All-In-One Printer
    Comm error 232 & no fax detected when receiving
    Oct 21, 2008 | HP LaserJet 3055 All-In-One Printer
    Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
    232-A communication failure has occurred between the two machines.
    327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
    356-The remote user has pressed the Stop key, causing the session to be aborted.
    442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
    Aug 15, 2008 | HP Computers & Internet
    Comm. Error
    Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
    Jun 25, 2007 | Canon L120 Fax Laser Printer
    HP LaserJet 3055 All-In-One Printer Logo
    294 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
