Question about Lenovo ThinkCentre® A51 PC Desktop
No soundmax audio present.
The sound just went off.the icon on the tray says:no soundmax audio present.you cannot use soundmax control panel.i tried to reinstall the driver but still didnt work.it has mute sign on it.and the codec is not present in device manager.please help how to solve this.
  • rlopez0812 Jun 26, 2009
    i dont see anything like that.i am using desktop xp sp3
  • dan333archer
    dan333archer Oct 13, 2012
    You will need to first download your chipset drivers from the PC or motherboard vendor and run that , np need to reboot yet. You will also need to download the SoundMax from your PC or motherboard vendor and then install that and reboot your PC. The all should work fine. I don't know why the chipset drivers are the real fix with this issue. This did work for my Asus P6T Delux motherboard!
    Problem Solver:
  • 4 Answers
I need to ask. Do you have two speakers showing? One fat red one and one gray one as you usually see on computers everywhere?
Try this either way.
Go to Start, All Programs, Accessories, Entertainment, Volume Control and make sure you don't have a check mark in your Master Volume control found on the far left.
Are you using a Desktop or laptop?
Posted on Jun 26, 2009
  • Erich Powell
    Erich Powell Jun 26, 2009
    Did you find the Volume Control in accessories? Is it/Was it Muted?
I have asus p5pe-vm motherboard system which i bought 5 years back with windows xp installed, after that a year back i installed windows 7 and i cudnt hear any sound from my system... as well every time i...
http://directx.en.softonic.com/
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 16, 2011 | ASUS P5PE-VM Motherboard
I have no sound. maybe my computer has been muted
Check that sound drivers are ok as follows
  • Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the "Hardware" tab and then the "Device Manager" button.
  • Expand the "Sounds, video, and game controllers" heading to find your sound card. The name will depend on what sound card is installed on your PC. It will most likely have a name containing "audio." It should look something similar to the example above. You'll know immediately if there is a major driver error because an exclamation point (!) will show over the card's icon.
  • Double-click on the name of the sound card to open a new window. In the new properties window click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's onscreen instructions to update your driver. You can also contact the manufacturer of your PC for the most recent audio drivers. They can usually be found online.
if the drivers were OK, proceed as follows
You can check the system volume and adjust it as follows
No. Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Sounds and Audio Devices.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Move to Sounds and Audio Devices by pressing the arrow keys.
  • Press ENTER.
3 In the Sounds and Audio Devices Properties dialog box, on the Volume tab:
  • Adjust the sound volume by moving the Device volume slider.
  • Select OK.
  • Adjust the Device volume by pressing the RIGHT ARROW key for higher volume (louder), and the LEFT ARROW key for lower volume.
  • Select OK.
4 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
Apr 25, 2011 | Computers & Internet
On my motherboard a7v8x - x, there is no sound and i cant install soundmax drivers
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 18, 2011 | ASUS A7V8X Motherboard
I am using asus k8v-mx mother board, and im just finished reformmating my system using windows 7. The only problem i had is that my audio driver cannot be installed due to incompatibility results. Can...
1. first download this file:
audio.zip - Audio Driver for Win 7
2. right click on "Computer" and select properties. Open Device Manager.
3. Uninstall Soundmax.
4. Open that zip from step 1 and extract to a new folder on the desktop.
5. Run Setup.exe and complete.
6. Restart.
7. Once you are back you're sound icon will be missing from the tray and windows will reinstall the soundmax drivers.
Nov 28, 2009 | ASUS K8V-MX Motherboard
PLACA M925LR ESTE TEMA ES ANTIGUO PERO TENGO UNA PREGUNTA. LOS JUMPERS J2A/B/C/D Y J3/A/B/C/D DONDE ESTAN, LOS VENDEN? HAY QUE CERRARLOS PAR A PAR, POR AHI ALGUIEN DICE QUE ESTAN EN LA PLACA, ¿DONDE?
6. Restart.
Nov 27, 2009 | PC Chips (M925G) Motherboard
I need the driver for the SoundMax 1884 for
1st Download Driver from this site SoundMax Sound Driver
Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
Oct 01, 2009 | Computers & Internet
Soundmax integrated digital audio
1st Download Driver from this site SoundMAX Sound Driver
  • Driver will be install.
Mar 19, 2009 | Computers & Internet
No sound on my Windows XP desktop
Sound may be muted in the control panel
click the icon in the tray to bring up the
Sound control panel and check for a mute
Apr 23, 2008 | Microsoft Windows XP Professional for PC
Lenovo ThinkCentre® A51 PC Desktop Logo
3,021 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
