Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
ASUS P5N32-SLI Premium mobo w/ WinXP Pro (SP3). System dead
Hi --
My system has been running beautifully for several years. Last Tuesday, I rebooted the computer and when I came back, the system was dead. The power lights (on the motherboard and the chassis) are on, but there is no hard drive activity. Also, there is no POST beep at all. I replace the PSU with a brand-new slightly more powerful one (700W) with no effect. I replace the CPU (Intel C2D 6600) with a brand-new Intel Quad 6600 (both socket 775, both supported by the motherboard) with no effect. I removed the RAM (which should have the system complain at power-up, and still nothing. No monitor display, no hard drive activity, no POST information. I unplugged all internal PCI cards and all external connections, same thing. I cleared the CMOS memory, same thing.
Thoughts?
Thanks in advance --
Dave
    Problem Solver:
  • 16 Answers
After doing all of that and nothing has changed, sounds to me like your mobo is bad
Posted on Jun 26, 2009
Helo, i have updated the bios on asus p532n-e sli premium, and after instalation the sistem won't turn on.pls this is urgent. a nice day
According to your problem first check the bios update. Check that you have updated the bios properly. Run the motherboard in updated bios, so reset the bios. This may occur for another cause also. So check the electric outlet where the system is being plugged. Make sure that the SMPS is OK and compatible with motherboard. If the SMPS fulfil the minimum requirement of the pre updated motherboard then updated bios may not support. Check that you have installed the SMPS power cable in your motherboard properly. It will help you.
Jun 06, 2011 | ASUS P5N32-SLI Premium Motherboard
Asus P5n32 Sli Premium
There is a couple of things you can do to troubleshoot this.
If there is an on-board VGA (video) port on the back, try that.
Clear the CMOS. On that spec board there should be a coloured plastic jumper next to or near the motherboard battery like this >>>>>
If there is no jumper then remove the power cord from the back and take the motherboard battery out for half an hour then replace and see if you get a post screen.
If it still suffers from the same symptoms then there could be micro fissures between solder points on the motherboard as Intel's tend to run fairly hot.
This means you have to re-float the motherboard and is a last resort repair.
If you need anymore help or advice please post back.
Good luck.
Aug 12, 2009 | ASUS AI Lifestyle P5N32-E SLI...
Help on Asus P5N32-E SLI Motherboard and hard disk
I am an advocate of ASUS boards..rock solid...Vista on the other hand...problems occur out of no where...when problems arise you always have to ask yourself" what has changed"..and work backwords from there.
http://www.aa1consulting.com
Jul 26, 2009 | ASUS AI Lifestyle P5N32-E SLI...
System has been working fine for several years. Now on boot up, shows initial screen with ASUS information (motherboard model P5N32-SLI SE Deluxe, Press DEL to run Setup). No BIOS beeps. Warm reboot,...
Are you able to enter into the BIOS settings by pressing DEL?
If so, load default settings in the BIOS and try booting up again.
Best wishes,
Graemevm
May 05, 2009 | ASUS AI Lifestyle P5N32-E SLI...
ASUS P5N32-SLI Premium/WiFi-AP
they dont sell them u need clal asus .com ask f they have one 5 10 bucks ok or else just dont use it alsoways install i o shild 1st then mobo
Oct 13, 2008 | ASUS AI Lifestyle P5N32-SLI...
PCIe 2.0 compatibility
Yes it will work, though a nvidea card may yeild better performance overall in your system.
Feb 12, 2008 | ASUS A8N-SLI Motherboard
Extreme slow performance, cpu performance maxed out
Boot to safe mode and see if the problem is the same.
Have you checked for viruses and spyware?
Look in Control Panel/Admin Tools/Event Viewer, System and Application for red marks.
Do you have a temp monitor installed?
Have you changed anything in the BIOS? Set to safe defaults.
Oct 26, 2007 | ASUS P5N32-SLI Premium Motherboard
Need wiring harness guide for asus p5n32-sli deluxe motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-SLI%20Deluxe
You can get all the files you need here.
Download and print only the parts of the manual you need or it will be almost a whole stack of paper.
Good luck with this mobo.
I've had nothing but prob;lems with it.
I'm going back to my ecs that I know works.
I suggest you search "problems with p5n32-sli".
Oct 18, 2007 | ASUS P5N32-SLI Deluxe Motherboard
New Installation P5N32-E SLI
There is also a 4 pin power connector cable for the processor to connect onto the motherboard. Make sure that is plugged in. IF that still doesn't help, disconnect hard drive, video card, cd rom drive and floppy drive and any other pci cards in the system. Try booting it again at least to the bios. See if that helps.
Mar 27, 2007 | ASUS P5N32-SLI Deluxe (890552603794)...
ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
