Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My pool water is a little cloudy, the test strip says everything is ok what should I do?
  • 297 Answers
You can use a clarifyer but most likely you are not filtering enough.
A pool needs turned over At Least 3 times in a filtering cycle. Figure out how many gallons an hour your pump will do and then filter accordingly.
If you have 7000gl and your pump is 2000gph then you should be running you pump 10 1/2 hours a day/night.
Posted on Jul 09, 2009
  • 110 Answers
Having problems with water staying cloudy & a white scaly film on sides of pool.
you have some really hard water. Use a test strip to find out hoe much of what chemical you need to add to the water.
May 10, 2017 | Pool & Spa
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Have saltwater system 6500 gallon pool (18x48) opened pool with 4 bags pool salt, 1 bag stabilizer, 1 bottle algeaguard. Ran pump to dissolve salt first then turned on saltwater system, added algeaguard,...
Thank you for posting your question here on Fixya.com.
You need to be able to test at least chlorine, salinity, ph, alkalinity, and stabilizer. The best way is using test strips. If you have a sample of water tested at a pool supply store that will work too but frequent transportation is more costly than strips. The salinity should be about 3000 ppm, Chlorine should be between 2 and 4 ppm, alkalinity should be between and 80 and 140 ppm and the stabilizer should be between 30 and 50 ppm. Some say up to 100 ppm. Unfortunately higher stabilizer reduces the chlorine's ability to kill algae, etc. When the water becomes cloudy it is likely low on chlorine and is about to turn green. If the test shows low chlorine level then I would add shock to 10 ppm chlorine. If the filter system is working correctly then it should clear up fairly soon. I would not let anyone swim until the chlorine is between 2 and 4 ppm and you can clearly see the pool bottom.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! Thank you.
Aug 28, 2011 | Intex Pool & Spa
On return line of pool there is a constant air bubbles on fizzing sounds and pool remains cloudy at all times
The cloudiness means you should check the chemistry of the water. If you have test strips it should tell you if you have a problem. The constant air bubbles may or may not be causing cloudiness but they are probable caused by an air lead in the suction side of the pump or the piping leading into it. The pump pot should have a clear lid and if it is clear enough to see through it you are likely to see a lot of air above the water. Because air is being circulated less water is circulated and therefore less chlorine is being provided to the pool. If you need ideas on where to look for leaks in the suction system then just ask. I hope this helps.
Aug 20, 2011 | Hayward SAND FILTER, PRO SERIES
My water is cloudy and says salt level low.....it seems salty enough as I can feel and taste it. Is there chemicals I am supposed to be adding or does this system keep it clean all alone just by adding...
While your problems are likely greater than just the salt content in the water I can tell you that if you feel, or more importantly can taste the salt in the water your salt level is WAY TO HIGH, not low. Have the salt level confirmed with an independent test either at a pool store or using a salt tester.
John
Jul 21, 2011 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
We have had a lot of rain and had to let water out of our above ground pool do we need to add more salt to the pool
It is quite possible that you do
It seems every one on here doesn't realize that they need to have the salt water test kit that reads #;s not color
If you were to close to minimum then you will need more salt
What you need to do is get the strips and test
you need to be as close to 3000ppm as possible
lower than 2800ppm and you will not be generating enough chlorine
any higher than 3500ppm and you could get cloudy,taste bad, and trigger an alarm for high salt
Bottom line is you can not guess at the salt content!
Jul 16, 2010 | Intex Automatic Salt Water System for ...
Intex 3-way test strips
I use my 3 way test strips and copper strip when the pool is not running After 15 seconds the readings are using a bit high. After 3 - 4 minutes the readings are perfect.
May 09, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
835 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
