Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
My vacuum starts but stops immidiately I replaced on/off switch & belt but it didn't help me its still doing the same thing. Please help me out
    Problem Solver:
  • 3 Answers
It could be the power source .e.g. The lead or plug with a broken wire making intermittent contact.
Posted on Jun 26, 2009
Brush bar does not turn when unit is turned on, belt is intact and no noticeable defects.
LOts of these units have a switch for brush or you have to pull back on the handle to start brush.
Hope this helps Mike
May 23, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
My Oreck XL 21 stopped self perpelling, what so I need to replace or fix?
There is a small drive belt that turns the wheal that may need replacing open the drive belt compartment and replace like the brush belt. Turn the vacuum upside down to take out the screws it helps keep things in place.
Dec 26, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Replacing belt
Hello Cheryl,
Please see detail instructions here.
Good Luck,
Rocky
Nov 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I bought a Bisell Pro-heat carpet shampooer and had the belt break after one use. Tried to buy replacement belts only to discover that store out of stock. Question: Is there such a thing as a "generic" or...
No unfortunately not. Some brands of vacuums and steam cleaners have similar belts that can be used on several different models, however this Bissell carpet cleaner has a very unique belt, that is really unlike any other belt on the market today.
I'm sorry to hear that your local store was out of stock on these. We do however have these belts in stock ready to ship today if you haven't already found them. We do offer free shipping & no tax (except VA). Here's a link to the brush belt for your Bissell:
http://www.govacuum.com/bissell-proheat-steam-cleaner-replacement-belt-part-0150621.html
Please feel free to add a comment if you'd like help installing the belt, I'd be more then happy to walk you through this.
If you found this helpful, it would be greatly appreciated if you rated the repair helpful, or left feedback.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
Replace the belt
I dont have an answer for tha specific model but most machines all have the same set up when it comes to belts, so please feel free to check this video out belt replacement.
hope this helps...
Sep 15, 2009 | Regina ElectrikBroom RG100 Vacuum
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I checked the belt and it has not broken, but when I start to vaccum the spinning head stops, and I start to smell a rubber smell...Do you think I need to replace the belt, I did get some string caught in...
Yes you do need to replace the belt they stretch out. Think of a belt like a big rubber band if you were to stretch it out and hold a lighter to it the rubber band would stay stretched out. That is the same thing that happens when you get it caught on string or an area rug the brush stops but the little metal shaft keeps spinning creating heat and stretching the belt. Visit www.stevessewandvac.com for belts, bags or any other vacuum need.
Aug 13, 2008 | Bissell Vacuums
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
95 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
