Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
  • 784 Answers
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Posted on Jul 03, 2009
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom dishwasher of fisher and paykel wont drain
Check the filter sump is clear and there are no blockages in the rotor cavity. If you hear the rotor noise when it is in drain cycle then blockage is inside the rotor or filter sump cavity. Assuming the top drawer is working ok, the drain hose at kitchen end might be ok. The drain hose within the drawer could also be an issue. Try to run the dishwasher with a Finish dishwasher cleaning kit (from super market) after following the instructions on the kit. First empty dishwasher with a small cup.
If the rotor is silent during drain cycle then you have a bigger problem - faulty rotor circuit.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
DD603 model & top drawer totally dead, no lights but bottom drawer 100% Your thoughts plse.
possible causes
  • top drawer controller has lost power - replace power filter plate located at the base of dishwasher under bottom drawer controller
  • itself is faulty if you are getting some lights on the panel
  • thermal relay has tripped. It is located inside the heater element at the base of the drawer. The whole heater needs to be replaced.
Make sure the dishwasher is disconnected from the mains power supply when working on it
Jul 26, 2012 | Fisher and Paykel Dishwashers
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer drains into top drawer
I can offer a PERMANENT fix for this! That machine has never been installed properly since day 1 I would bet, and a series of techs have come thru unable to fix it right, or they keep selling you those "flappers" that fix the issue for a short period of time.
The way to fix cross-draining fisher paykel dishdrawers is to install a dual-air gap. You can get them from fisherpaykelparts.net here: http://www.fisherpaykelparts.net/index.php?categoryid=113&productid=7
Install one of those and the machine will work better than it ever has!!
Aug 15, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
605 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
