Question about Xantrex Technology Xantrex 458 10 12 Freedom 1,000 Watt Inverter/Charger
What is the replacement for trace model L1512SB
Replace the wiring to the heating element
Make and model number, please?
Otherwise, all we can suggest is that you trace the wiring, making a note of the harness colours and then ring them through so that you can be sure that you're replacing the correct cable.
Mar 03, 2015 | Dryers
Why my tv shut offf sometimes and then turn on ??
Many of the newer type televisions develop power supply problems, and even though problems vary from make and model, many can be traced back to power supplies. The most common troubles stem from capacitors that are on verge of failing or have failed when set will not power up or will power up, shut down on its own, etc. I do not recommend owners repair their own sets due to high voltages and the level of knowledge needed to tackle such a job. There are though companies that supply capacitor "kits" for many makes and models, so if service tech traces to capacitors most are available. First though weigh the cost of repair versus the cost of a new replacement.
Jun 20, 2014 | Panasonic TC-54PS14 54" HDTV Plasma TV
Chamberlin garage door opener has 3 terminals 1 2 3 2- photo eyes 1- pushbutton (doorbell type) 1-remote What is the correct connections?
1 WIRE WITH RED TRACE
2 WHITE WIRES WITH NO TRACE
3 WIRE WITH GRAY OR BLACK TRACE
ALSO THE WIRE TO THE WALL CONTROL MUST BE WIRED CORRECTLY - DOUBLE CHECK - IT TELLS YOU WHITE AND RED TRACE OR 1 & 2
YES THE POLARITY MATTERS ON THE WALL CONTROL EVEN IF IT LOOKS LIKE JUST A DOORBELL BUTTON.
HOPE THIS HELPS
Oct 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
My tv died last night no power at all no stand by light or sound It is a Samsung Tantus Model number TXN3298HF CRT
check first power ac cord by removing back cover trace if ac line voltage found, check for possible burn fuse. make a record after that scenario trace and log voltage trace from power supply ckt area.
Mar 26, 2010 | Samsung TXN3298HF 32" TV
DELL d600 model pp01l
If your motherboard traces are damaged, I would highly recommend replace the board. This model laptop can have considerably high current running through that jack and traces. if anything is weak it will burn through.
Or take it to a electronics specialist.
Oct 11, 2008 | Dell C600 (002UH) Motherboard
No sound pretty pic
Check the speakers, if they are okay trace the speaker lines and find out the audio output ic, trace out the supply lines and check the voltages, if that is okay, replace the ic.
Jan 22, 2008 | Philips 27PT543S 27" TV
Xantrex Technology Xantrex 458 10 12 Freedom 1,000 Watt Inverter/Charger Logo
55 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
