Question about Symbol MC 9090 (sym-mc9090gk0hbega2r) Wireless Portable Terminal
Functions keys for page up or page down - Symbol MC 9090 (sym-mc9090gk0hbega2r) Wireless Portable Terminal
  • Stuart Pilkington-Way
    Stuart Pilkington-Way May 11, 2010
    There are 2 wasy to change the arrow keys to function keys the first is to create a regedit string or if using a telnet program such as wavelink create custom macros within the configuration. Let us now how you are using the keys.
  • BarcodeGuru May 11, 2010
    What application are you using? Have you tried the up or down arrows at the top of the keypad?
Page up page down doesn't work
Some laptops require you hold down the Fn key because some keys perform more than one function.
Aug 26, 2014 | Dell Computers & Internet
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
How to function Fn
Step 1:
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key. The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function. The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop. Use the drop-down menus on the support page to choose the specific product line and then model of your laptop. Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys. Find the sequence of keys you need to press to unlock the function key on your laptop. Press and hold the function key on the keyboard and then press the other keys required to unlock it. Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys. Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
b>
Feb 15, 2013 | Gateway NV52L06u Laptop PC
How do I the ALPHA f1 function menu to appear so I can enter fractions
Hi...
You can access F1 by
  1. Press and Release "ALPHA" Key
  2. Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example:
pressing UP and DOWN keys navigates the screen up and down
if we press ALPHA key and then UP/DOWN key, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions.
if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
Mar 18, 2011 | Texas Instruments TI-84 Plus Calculator
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 26, 2011 | Compaq Computers & Internet
Which is an function key in keyboard
(FuNction key) A keyboard key that works like a shift key to activate a second function on a dual-purpose key. Commonly found on laptop keyboards, the Fn key is often used to control hardware functions such as screen brightness and speaker volume. The Fn key may also be found on extra small keyboards for desktop computers, typically for Page Up and Page Down, which are combined with Up Arrow and Down Arrow. See function key.
Feb 24, 2011 | Samsung Pleomax PKB-700B Keyboard
Unlock function key
you can fix the problem by following the steps
  1. tep 1 Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open your web-browsing program and navigate to the support section of the website if you do not have the manual that originally came with your laptop (see Resources below). Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
  2. Step 2 Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys.
  3. Step 3 Find the sequence of keys you need to press to unlock the function key on your laptop and note them down. Press and hold the function key on the keyboard and then press the other keys required to unlock it.
  4. Step 4 Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
  5. Step 5 Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
thanks
May 20, 2010 | Toshiba Satellite 1410-S173 Notebook
The pictures on the f keys..Im pushing them but nothing is happening..for example..f1 is home key..not going to home page when I push it
The function keys that have the pictures on them have dual functions. You need to press and hold down the Fn key and then press the Function key with the symbly/picture to get the 2nd function/option.
Eg. For the Home key press Fn plus F1 key.
Jan 04, 2010 | Logitech Cordless EX 100 Mouse
Can not figure out how to make page up/page down keys work on acer aspire 6920-6621
make sure that the "Scroll Lock" is not engaged and if the page UP and DOWN on the keys are typed in BLUE, then press your Function (FN) keys first, then press the page UP and DOWN.
if you have other questions please lemme know
Nov 02, 2008 | Acer Computers & Internet
Symbol MC 9090 (sym-mc9090gk0hbega2r) Wireless Portable Terminal Logo
555 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
