Frig came with the home - I have the freezer at normal temp, but condensation (frozen) is forming on the top side -- Why
Good Afternoon Friend,
I understand that your Frigidaire refrigerator has frozen condensation in the freezer area. Typically this will happen if the door is left open, left open for too long, or if the door is not sealing properly. I suggest making sure that the door is closed, as well as not leaving it opened for extended periods of time. When the hot humid air hits the freezer it will cause frost. Also, you might want to check the seal around the door, and make sure it is not damaged in any way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave your model number in the comment section. Hope this is helpful.
-Best Regards-
WP
SOURCE: Delfield Refrigerator/Freezer Condensation forming outside door seals
I would expect at the very least a heater circuit around the freezer door. Some of the commercial units also have sprung doors to keep the doors firmly shut which you could check by opening the doors. Door heater circuits are normally very reliable and it would be worth checking the voltage is getting to them, they are also a pain to change out. Hope this helps.
SOURCE: Jenn-air side-by-side: freezer & frig cold on the bottom not top!
It sounds like 1 of 4 things...
1. It could be related to the evaporator becoming Iced over and when this happens it insulates the area iced over and the temp rises...this is caused from the defrost cycle not being activated...(Thermostat, or loose or broken wire)
2. There is a device called the thermistor which senses temp and Ice build up which will cause the unit to go into defrost...this could be bad.
3. The previous fixes may cost a little but not as much as the next which could be a restriction in the evaporator. This is serious and usually requires the replacement of the same...very pricey. Is there only 2 compartment or a pull out drawer for freezer foods..If so you could have an isolated problem in the upper freezer compartment which may be remedied without great cost
If your husband or yourself ..or a handy person can access the back of the freezer by removing the back panel I'm sure you will find either lots of Ice good..as far as cost to repair goes....or no Ice...bad...bad.. as far as cost to repair..the later falls in line with a restriction.
I hope I have helped....please rate me ...The Fang
SOURCE: GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
