Question about Ricoh Aficio 450 Copier
Please help re: Xerox 2515 large format copier
I'm using a Xerox 2515 large format copier. When I try to insert the sheet of paper to be copied the machine stops running and the displays a "J". I don't have a manual with my machine so I can't check it out. Please help.
  • 92 Answers
The first step is to pull the paper out and see if the feed rollers have left a mark on the paper that would mean your rollers are turning just not picking up the paper if this is the case remove the paper tray and with a wet rag clean the feed rollers always easier with a flash light keep in mind they may need to be replaced call 7734748865 il b happy to help
Posted on Jun 26, 2009
  • chicagojoeco Jun 26, 2009
    the first step is to pull the paper out and see if the feed rollers have left a mark on the paper that would mean your rollers are turning just not picking up the paper if this is the case remove the paper tray and with a wet rag clean the feed rollers always easier with a flash light keep in mind they may need to be replaced call 7734748865 il b happy to help
Code error 061-315 copy not coming
change the laser and it will be done. please don trouble your self just do as i am saying.
. remove the cover were the paper falls when you are making copies and take off the front cover until you reach the laser unit and replace with a functioning one. if you want some more help contac me on my cell number 00258 846427869
Apr 27, 2015 | Xerox Workcentre 5225 / Copier, With...
How to replace toner cartidge of the Xerox Copier 5225 machine?
The toner cartridge is located in the upper centre of the front of the copier. Open the front door, slide out the cartridge until you see the top handle, whilst pulling out hold the top handle to avoid the cartridge tilting and leaking any excess toner inside the machine.
Before inserting your new cartridge, gently shake it from side to side to ensure even distribution of the toner. Slide the new cartridge in until you here a click, then close the front door. Your copier may go into a calibration routine for a minute or so if the developer has been starved of toner. If it hasn't, it will be ready to copy straight away.
For a quick user guide on the copier go to http://download.support.xerox.com/pub/docs/WC5225_WC5230/userdocs/any-os/en/EN_Online5230_5225_5222_QUG.pdf
Hope this helps.
Jan 21, 2011 | Xerox Workcentre 5225 / Copier, With...
My Xerox 4150 keeps taking lots of blank pages through when printing multiple page documents sometimes 30 or 40 at a time
Two possible solutions to your problem.
If you are talking about grabbing more sheets than one from the tray, you need to make sure the tray guides are up flush against the paper.
If on the other hand you are talking about scanned/copied jobs, check the setting for your scanner, it may be set to letter size which is longer than A4, so the machine thinks it needs another sheet to complete the job causing a blank page to be sent.
Hope this helps
Jan 10, 2011 | Xerox WorkCentre 4150 Black and White...
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Problems copying with my Xerox 2515 copier
Paper goes on the bottom first. original goes in top next
Jul 31, 2009 | Ricoh Aficio 450 Copier
My Xerox Workcentre 385
Your probably got the copy key (readout) set at 10 copies. Try to go to the Xerox site and query for the instruction manual, this works most of the time. This will tell you how to negate the multiple copies
Jun 17, 2009 | Xerox WorkCentre 385 Laser Printer
Xerox xc356 copier
TRY TO CLEAN THE RUBBER ON FEEDING PAPER WITH A DRY CLEAN CLOTH AND DROP A SOME ALCOHOL IN CLOTH AND CHECK THE PAPER PATH IF HAVE SOME A LITTLE PAPER ON PATH PAPER... ABOUT CATRIDGE...TRY TO REPLACE A NEW CATRIDGE.. DO THIS NECESSARY UR COPIER IS ON. panlaqui08@yahoo.com.ph
Jul 05, 2007 | Xerox XC356 Copier
Ricoh Aficio 450 Copier Logo
262 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
