Question about Poulan 952801953 Electric Chain Saw
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
How can I put the chain back on track?
  • Anonymous Mar 13, 2014
    The chain has fallen of and am trying to put it back on, but don't know how to do it
  • Anonymous Mar 23, 2014
    chain came off track was loose before
    Problem Solver:
  • 8 Answers
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Posted on Jun 26, 2009
  • Tom Brooks
    Tom Brooks Jan 20, 2014
    Thanks, man. That's all I needed.
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
When I push the button and start cutting, why does the chain kick off?
Review the new chain installation procedure to be sure it was looped over the drive gear correctly. Also, the bar may have readjusted itself after you applied tension and tightened the hardware.
Apr 05, 2016 | McCulloch 14" Electric Chain Saw Mcc1514
Rubber"chain" off track
Put it back on track
Apr 28, 2015 | Building Materials
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Chain came off, how do put it back?
Remove the cover. Loosen the two bolts that hold the chainsaw bar. Slide the bar back (it has a long slot for adjustment) until the blade can be lifted out of the track and sprocket. To replace the blade slip it onto the sprocket and the bar. You must hold the bar level while replacing the blade. Be sure the blade fits into the track around the bar. Once in place double check the placement on the sprocket and pull the bar outward until all the slack is removed from the chain blade. Holding firmly, (it would help to have someone assisting) keep the pressure on the blade and bar while replacing the bolt nuts. Then replace the hood cover. Smile.
Sep 27, 2014 | Worx Jaw Saw Replacement Saw Chain
Replace chain
Do you know that chains can be resharpened? I suggest you find a shop that services chain saws and have it sharpened. If you want to replace the chain a good shop can get you one or make one.
Oct 31, 2013 | Poulan 1420 14Inch 20 HP Electric Chain...
How do you put the chain back on the track of a Husqvqrna e series 235 chain saw.
You need to make sure the blade is not damaged. You need to release the chain tension screw, most cases; you turn in counter clock wise to release the tension rod. Do it in the reverse when you reinstall chain to tighten it back up to operating conditions.
Aug 25, 2011 | Husqvarna 450 e-series 18" Chain Saw
Poulan 952801953 Electric Chain Saw Logo
825 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
