To log into your WRT54G, open a Web browser on a computer that's connected to your router and go to
http://192.168.1.1/ - the default
username is
admin and the default
password is blank (leave the field empty)
In the
Setup tab,
Basic Setup subtab:
DHCP Server should be set to
Enable.
If you had to change this setting, be sure to click the
Save Settings button.
In the
Wireless tab,
Basic Wireless Settings subtab:
The first data item is
Wireless Network Mode. For reasonable performance, this should be set to either
Mixed or
G-Only. You should be able to connect your NOOK even if it's set to
B-Only, but that would be a very unusual setting and would give slower networking.
Wireless Network Name (SSID) is the name of
your Wi-Fi network. If it still says 'linksys', change it to something different-but be aware that you'll need to reconnect all of your current Wi-Fi devices using the new SSID. That's a pain in the behind, but using the default SSID will cause you lots of connection grief if someone else installs a Wi-Fi router with the default SSID, because your devices won't be able to tell them apart.
Write down your SSID, being careful to distinguish capital letters from small letters, so you'll know what it is.
Wireless SSID Broadcast should be set to
Enable. Otherwise, your NOOK won't see your network. You could type in your SSID, but that's a pain in the behind that you don't need. There's no reason not to enable SSID broadcast.
If you had to make any changes to these settings, be sure to click the
In the
Wireless tab,
Wireless Security subtab:
Security Mode: write down which of the choices is selected:
- Disable
- WPA Pre-Shared Key
- WPA RADIUS
- RADIUS
- WEP
I say to write this down just in case you run into more trouble and need to ask someone for help.
If 'Disable' is selected: you have no security on your Wi-Fi. Anyone can use your Internet connection, and anyone can listen in if they're in range. If you send unencrypted passwords, email, etc., they could see what you send. Most public Wi-Fi systems (McDonald's, Starbucks, B&N, etc.) have no security.
If either 'RADIUS' choice is selected: these settings are used for large organizations with stringent security requirements and a dedicated authentication server. Your NOOK cannot connect if either of these settings is used. You almost certainly don't want to be using either of these for a home system.
If the 'WPA Pre-Shared Key' choice is selected: WPA offers good security for Wi-Fi and is the best of these choices for home use.
- WPA Algorithms should be set to TKIP. This is the normal setting for WPA. I don't know if your NOOK will connect if you set it to AES, which is normally used with WPA2 rather than WPA.
- WPA Shared Key is the access key for your network. Write it down, being careful to distinguish capital letters and small letters. You'll definitely need this key in order to connect your NOOK or any other Wi-Fi device to your router. Don't change this unless you're prepared to go back and reconnect your other Wi-Fi devices. Unfortunately, there are some punctuation marks that you can't enter on the NOOK keyboard, and if your WPA passphrase contains one of those you may need to change the passphrase in order to connect your NOOK.
If 'WEP' is selected: the WEP security system is a weak system, easily cracked by knowledgeable hackers. However, many older wireless devices and some of the cheapest new wireless devices can't handle anything better than WEP. This isn't a good situation, but you work with what you've got.
- Default Transmit Key should be set to 1.
- Passphrase is not important. It is not your network's access key. Ignore it.
- Key 1 is the access key for your network. Write it down. It will be either 10 or 26 characters, containing only the numbers 0-9 and the letters A-F. You will definitely need this key in order to connect your NOOK or any other Wi-Fi device to your router. There's no reason to change this, and if you do change it you'll have to go back and reconnect your other Wi-Fi devices.
Save Settings button. Any changes in this section will also require that your existing Wi-Fi devices be reconnected.
In the
Wireless tab,
Wireless MAC Filter subtab:
- Wireless MAC Filter should be set to Disable. If it's enabled and set to Permit only mode, only the devices listed on the MAC Filter List can use your Wi-Fi. If your NOOK isn't in the list, you can't connect your NOOK. Bad ju-ju, huh?
Save Settings button. Changing this should
not require your current Wi-Fi devices to reconnect.
It's possible to add your NOOK to the MAC Filtering list and then turn MAC Filtering back on. But that's beyond the scope of this posting. I will, however, mention that your NOOK's MAC address is listed in its Settings screen-on page 2 if it's a NOOK 3G.
In the
Wireless tab,
Advanced Wireless Settings subtab:
- Authentication Type should be set to Auto. Do not set it to 'Shared Key'; this won't work with NOOK. Auto should work with any WEP-capable devices. If it's set to 'Shared Key', change it to 'Auto'-this shouldn't affect any of your current Wi-Fi devices.
You should now be able to connect your NOOK using the SSID and the access key that you wrote down.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
