Question about Fellowes 91011 F325 Binaural Headset Headset
Where can I get connections to plug into my computer? Or for that matter into a regular phone jack.
  • 5,455 Answers
Maplin if you live UK. Radio Shack for the USA.
Posted on Jun 26, 2009
We do not have an Ethernet socket on our computer please advise
Plug the extender into the electric socket in your home.
Whatever your router name is needs to be set up on your router and the words added to the end of your wifi name. _EXT.
I set mine with the same password as my normal wifi and saved it so it automatically finds the Extender unit.
Whe
Jan 02, 2015 | Computers & Internet
Why won't my magic jack work plugged into the wall outlet?
Magicjack uses the internet. It has to be hooked up to a computer using the internet. Its just skype for regular phones. Skype is free. magicjack cost 20 bucks. its a scam
Oct 27, 2014 | Cell Phones
Plug for pc speakers wire
To use the speakers on the TV when you connect to a PC, get a 3.5 mm M/M audio cable (it may be called a patch cable or audio aux cable) and connect it to the PC audio in port to the left of the composite A/V ports (that's the group with 3 RCA jacks yellow (video)/red(R audio)/white (L audio)). The other end goes into the computer's line out (speaker out) port - which is generally colored green. Otherwise your regular computer speakers will play the audio.
If you want the TV's audio to output to external speakers, use the headphone jack (sometimes labels Phones, again a 3.5 mm plug) or a set of speakers/receiver that takes an optical audio connection. The optical audio jack is between the two coax connectors. Please note using the headphone jack will force the internal speakers off.
I hope this helps.
Aug 31, 2010 | Protron PLTV3250 32 in. LCD Television
When we put in our security system we were conected to a regular phone line, however we've just recently have our tv, computer and phone line tied in on cable. What do I need to do to have my security...
On your cable box it where your regular phone is plugged in, you need to take a regular phone cable and cut it, take that Green and Red wire to the series jack green and red... and take the yellow and black back to a phone jack. now plug your phone in that jack and it should work just fine.
Aug 31, 2010 | GE Security Simon 3 Wireless Home Security...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
I just changed from DSL to FIOS, and now my fax/printer/scanner (all-in-one) will not print. I have an ethernet cable connected from the printer to the FIOS router, and who knows where to plug in the phone...
First, the phone connection to the fax simply needs to come from a regular phone jack. You will need to have a regular telephone number in order for it to work. As I understand it, FIOS is a fiber network, which means everything is comming to you via the internet. Faxing does not work over internet telephony
On to your printer.
If you had connected the printer through ethernet before, the IP your computer thinks the printer is on is most likely no longer valid. You will need to either reinstall your printer (easiest solution - recommended), or re-connect to it manually (requires much greater skill and knowledge).
I cannot assist you with re-connecting it manually, so your best bet is to simply re-install the printer.
Good Luck!
Aug 06, 2009 | Office Equipment & Supplies
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
When I send a fax that is 3 pages long, only the first few lines print out on each page on the receiving end no matter how many times I try to resend it.
It could be that YOU have a nosiy phone line or the recipient has a DIGITAL phone service.
Listen to your dial-tone with a regular phone plugged into the wall jack.
Dec 16, 2008 | Canon Office Equipment & Supplies
Dial tone
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
Jun 22, 2008 | Radio Shack 433575 Cordless Phone
No Dial Tone on phones or modem
if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
good luck
wg
Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Fellowes 91011 F325 Binaural Headset Headset Logo
60 people viewed this question
Top Fellowes Radio Communications Experts
eradiostore
eradiostore
Are you a Fellowes Radio Communication Expert? Answer questions, earn points and help others
