Question about Black & Decker Garden
Black and Decker Reflex Plus auto feeds line and uses all up inside about 30 seconds
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 313 Answers
SOURCE: black and decker grasshog trimmer line feed problem
email publication@bdk.com or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Posted on Jul 28, 2008
  • 9 Answers
SOURCE: how do I rethread the
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Posted on Jul 30, 2008
Hightower971
  • 183 Answers
SOURCE: auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
Posted on Apr 28, 2009
rycgl
  • 1545 Answers
SOURCE: Where can i buy a spool cover for Black & Decker
I have been unable to find any information on that model. Maybe one of the newer models that have the 10" cut feature have parts you can use. Go here to look at them and their parts. Check the ones starting in the 12th row...with model 82300...click on a model...parts list with diagrams and prices will come up. You should have some luck with this at some point. Happy hunting!
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Posted on Aug 07, 2011
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
My Black & Decker Reflex Strimmer GL570 does notautomatically feed out the line.
disassemble the string part and clean it,,, it is common for them to get gluped up and not feed. All so make sure you have it wound the right way.
Jun 16, 2011 | Black & Decker Garden
My auto line feeder won't stop feeding line out. any suggestions?
Rewind your line the opposite direction you wound it on this last time.
If it is wound in the wrong direction, it will continue to feed out while running and that is your problem.
I hope this helped,
Please Rate Me
May 04, 2010 | Black & Decker Black and Decker & Grass...
My weedeater with auto line feed will not stop feeding the line when in use.
Did you ever get an answer to this problem? I'd like to know because I have the same problem with my cordless 14" Black N Decker Gass Hog. I rethread it, but the line continually feeds and is out in about 2 minutes.
May 03, 2010 | Black & Decker String Trimmer Cordless 12"...
Feeds line almost constantly
There is a recall on the head units on some of the electric trimmer models,I dont know all the details but one recall is for the head unit actually flying apart. I thought I would tell you,I would contact black and decker and see if yours is one of the recalls.
Aug 10, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed will not work
I think your problem is the little plastic ( white ) lever ( part# 598435-00 ) on the inside of the housing that holds the spool. Mine was working fine and then it just stopped feeding line altogether. I would order a couple (3-4) so you have them in stock. Looks like a part that will wear out fast. I wish they still sold a bump type weed eater. Hope that helps.
May 28, 2009 | Black & Decker 14" Grass Hog Xp...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
How to feed line into a black and decker trimer/edger model st6000 electric?
The ST6000 uses centrifugal force. Once you mount the new spool of string and thread it out of the feeder and into the housing below, plug it in, give it power and hold the line feed button down, feeding the line. Within seconds, the line will feed out through the head and you'll be in business.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
How do I rethread the cutting line on a black and decker strimmer reflex plus
Jul 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
602 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
