Question about Bruder Cat Skid Steer Loader
Bobcat keeps blowing fuse
My alt-kits fuse keeps blowing every time i turn on the air??
Why does it keep blowing the alt fuse?
fuses blow because of excess current flow ( dead short)
check that the wire to the alternator is on the correct terminal
Apr 27, 2015 | Cars & Trucks
Why does fuse keep blowing on green wire that goes to starter on Miller bobcat welder
means you have a dead short someplace in the starter circuit possibly the solenoid
Apr 07, 2015 | Miller Welding Tools
Bobcat 773 wont restart after dying out where do i start?
if the bobcat starts and then runs for a short time then dies the first place to look is the fuel system.fuel filters are the most common problems that i see replace those first.i have also found some junk inside the pickup tube inside the tank.there is probably a ball type hand pump to prime the fuel system.give that a squeeze and see if its hard.if thats the case there shoud be a small screw on top of the fuel filter.loosen that screw and see if fuel comes out when you sqeeze the ball.if your changing fuel filters this is also where you blead air from the system,keep pumping untill there is only fuel and no air.if you still get air after pumping for a long time then your sucking air into the system between the tank and pump.after you get fuel there close the screw,loosen the injector lines going to the injectors,crank the engine,and tighten when fuel comes out (keep clear because that is high pressure fuel).after you get fuel at all injectors and they are all tightened it should start.
May 26, 2014 | Bobcat 773
Replaced AC with converter kit and ac still does not blow cold air.
could be fuse or relay causing pump not to kick on...also could be clutch on pump has failed...somethings you might check...
Aug 18, 2012 | 1992 Honda Accord
2006 hyundai santa fe keeps blowing alt fuse
Have you had the alternator tested off the car ?
Jul 09, 2012 | Hyundai Santa Fe Cars & Trucks
Air suspension modular fuse (10) amp keeps blowing, why?
something is drawing too much current, pump running full time due to leak in air shock or line.
have a mechanic take a look at it and sit down before they tell you how much it is going to cost.
take a look at www.strutmasters.com for a kit to turn it into a regular shock and spring set up. One part of this system after another will need to be replaced, convert it or sell it.
Nov 26, 2010 | 2004 Lincoln Town Car
Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Jul 19, 2009 | Bruder Cat Skid Steer Loader
Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
May 26, 2009 | Jandy AQUALINK RS TELELINK KIT
AC keeps blowing fuses
Fuses are a protection device and I guess that this is for the condenser section and compressor. If they blow right now when it is turned on would indicate that there is a short in the wiring or motor or compressor. If it trys to start and the outside fan starts and the compressor just humms and blows fuse, you have a locked compressor. Might check run capacitor or install a hard start kit and see if it will brake it loose, if not bad compressor
May 31, 2008 | Ruud UBHC Air Conditioner
Bruder Cat Skid Steer Loader Logo
479 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
