For some time I have been having problems with my cell phone. People report that when they ring there is often a long delay between dialing the number and the phone ringing or often the phone does not ring at all. Also when I answer the phone it is several seconds before I can hear the caller. I thought the problem was my phone so I purchased a new Samsung phone today and transferred the SIM card into the new phone. But both problems continue. The service provider is AT&T. I am thinking that the problem is the SIM card but cannot find information about faulty SIM cards.
PTT switch on mode always appear on the screen.. When its appear i cant use my phone.. I have to switch off my phone before i can use it again..PTT switch on mode always appear on the screen.. When its appear i cant use my phone.. I have to switch off my phone before i can use it again..
You can't post conmments that contain an email address.
Sim cards are usually very reliable but seeing that you have changed the phone and still the same result then I would try replacing the sim.
Does this prob occur only when you are one place IE ( work or home) or doeas it happen all the time?
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
XX = your voicemail number
YY = delay (in seconds) before call is diverted to voicemail
The delay must be a multiple of 5 and the maximum is 30 seconds
Generally (without knowing what phone yopu have) you need to press menu, arrow up to answermachine or TAM then press OK then arrow up to settings or TAM settings then press ok then arrow down to answer delay/ring delay/ring number press ok then use arrow keys to adjust rings, when on required number, press ok.
have you tried the faqs.from here http://motorola.com/consumer/v/index.jsp?vgnextoid=06e1dd9fc0e2b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00002&show=globalSupport&productID=48bfe2f9eb3d9010VgnVCM1000008206b00aRCRD
that's controlled by your service provider, give them a call, they may be able to control the amount of time before it rolls to the message bank. If it's a GSM phone, you can set that yourself, like so:
To get the current call forwarding status, enter *#61#[SEND] into your phone.
Write down the number(ignore the +1), this is the phone number that your calls are currently being diverted to.
Enter **61*number*11*[delay]#[SEND]
into your phone using the phone number (numbers only) as reported by
the status & the delay can be set to (5, 10, 15, 20, 25, or 30)
seconds.
To verify that the settings are correct, enter *#61#[SEND] into your phone.
PTT switch on mode always appear... and i cant use the when it si appear..
