Question about Sanyo SR-1030W Top Freezer Refrigerator
Freezer will not freeze
I have turned the controls up in the frig part to try to keep the freezer cool.
The freezer will not freeze.
Questions Does the unit have a separate motor for the freezer? or just a separate thermostate?
The unit is in a rental which I cannot access since I'm in West Virginia and the unit is in California
  • 77 Answers
On this model there are no fans. make sure that the condensor is clean. It might be the t-stat
Posted on Feb 19, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Our fridge is not keeping cool. both the fridge and freezer stopped working yesterday, then we vacummed it out- the freezer works but the fridge is only at 39 degrees. Help?!!!
If your freezer is working properly.(that is it freezes ice)and frig is at 39 dg then you most likely have a problem with air flow . set thermostat and air control at middle setting and leave there for a few hrs. You should see temps stabilize with some time.
Dec 31, 2010 | Kenmore Refrigerators
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer stays warmer than frig
Jim, chk for air diverter in wrong position
the fridge cools from freezer air flow direction control. Like a door. The more/less controls may be messed up.
May 14, 2009 | Home
The fridge section is getting too cold at the bottom
THE CONTROL THAT DIVERTS MORE AIR TO FREEZER AND LESS TO RE-FRIG SIDE COULD NEED TO BE ADJUSTED TO KEEP MORE AIR IN THE FREEZER SIDE , MAKE SURE ALSO THAT THE SMALL FAN IN THE FREEZER IS RUNNING , ALSO TURN THE THERMOSTAT CONTROL TO LESS COLD , IF YOU HAVE A THERMOMETER TO PLACE IN FRIG SIDE TRY TO KEEP @ APP 40 DEGREES IN FRIDGE SIDE SEE IF ANY OF THESE HELP
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Sanyo SR-1030W Top Freezer Refrigerator Logo
153 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
