Question about LG Washing Machines
My washing machine has a strong mildew, musty smell when we haven't used it for a day. Cleaned the tap in lower left corner and use the HE soap. Help!!
  • 97 Answers
Hello Friend, Your problem is simple to resolve. This is a common issue. It is possible that the water quality being delivered to the washer could contain higher than normal amounts of micro-organisms causing the growth of mold and mildew. Basically what is happening with your washer, when not in use the washer door remains closed trapping in moisture which is the perfect invironment for mold and mildew to grow. You should run a large empty load with bleach and from now on just leave the washer door partially open when not in use. This should resolve your problem. Happy to help, Tim.
Posted on Jun 26, 2009
Musty smell
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very, very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap ****/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called
"TIDE WASHING MACHINE CLEANER" which is very effective.
Service manual and more can be found at this BLOG of mine
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 12, 2012 | LG Washing Machines
Dishwasher has a bad smell in it. I did find a teabag on the bottom of it and removed it. But even after many washings the smell is still there. The dishes are being cleaned. Any suggestions?
Use vinegar in it over night You will need enough so that you can acutally see it cover the gasket material in the bottom of the tub. After that... start cycle and drain out vinegar. Start a cycle like you were going to do a regular wash. Open the machine when your sure there is water in the bottom of the machine. Add 1/4 cup bleach and 1/4 cup powdered dishwashing soap directly into the water let it wash normally. If you still have the nasty smell after this... the next thing to do is to purchase a mold and mildew remover / cleaner like "Mr Muscle" and spray it all over EVERYTHING on the inside of the machine until the bottle is half gone. Let this sit for 15 minutes... then start a normal wash but do NOT add soap or rinse conditioner. Unit is now ready for regular washing. You may get spotted glasses on the first wash.... but it should not repeat.
This should get rid of the musty odor.
Thanks for choosing FixYa, Kelly
Jul 04, 2011 | Whirlpool Dishwashers
Its a stale, manky smell on all the clothes when they come out.
Hi, You did not mention front or top loading machine so I am going to assume you have a front loading machine.
Do this to clean your machine. Run a hot wash with 1/4 cup NON-bleach "powdered dishwashing soap" (Dawn or Cascade) and 1 cup of bleach. Then run a rinse with 2 cups vinegar and finally a regular wash with cleaning rags and HE type laundry soap. You may hae to do the dishwashing powder and 1 cup bleach wash 2 times to clear a bad case of mildew build up. You will not find this in any manufacturers user's manual but it will rid your machine of the nasty / musty smells.
If you are using regular laundry soap this problem will repeat often. If your using HE laundry soap you should do the above procedure about every 90 days.
We would appreciate hearing any success or failures related to your post by a future response from you as to how the solution above worked out.
Kelly
Jan 11, 2011 | Washing Machines
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Clothes smell musty
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 19, 2008 | Kenmore 43052 Front Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
274 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
