Question about LG Heating & Cooling
A/C leaking water on floor
Installed A/C in the top of the window as window is street level, now it is leaking into the room.
Maybe I have it on the wrong setting?
  • 334 Answers
Hey there, window units are made to drip their water outside. All youo need to do is make sure it is tilted ever so slightly toward the outside and not inside. Let me know if this doesn't work for ya.
seth
Posted on Jun 26, 2009
Water from condensation removed draining into the room.
Water is draining inside because your jury-rigged A/C is pitched the wrong way. Also, you are likely to find a wet carpet is the least of your problems when your incorrectly installed A/C winds up on the first floor or, worse yet, on top of someone. Find out whether an indoor A/C will work instead.
Jun 06, 2016 | Heating & Cooling
Hi, I have an air conditioner Frigidaire which is leaking in the front. The unit is in a window, in a 4th Floor and I don't have access to the back, how can I unclog the unit??. I am desperate!!!!
if it's just condensation leaking out the front of the unit it could be that the unit is not level in the window. If it's tilted too far into the room it will leak condensation into the room. Try to tilt it back just a hair so that the condensation leaks out the back of the unit.
Sep 02, 2013 | Frigidaire Heating & Cooling
Make : Weil-McLain Model : CG-5-SPDN Series 12 I have the above mentioned boiler which is located on the 1st level of a three story one family house, the area where the boiler is located is insulated.
You don't have an optimum distribution of steam in your house. Try closing a little bit the valves supplying the heaters in the lower floors. Close a little bit more until you get the desired balance.
Nov 06, 2012 | Heating & Cooling
Water leak fro dash bored
On the early 2000 model Grand Prix the issue with the water leaking into the passenger floor board is usually the seal that has come off near the blower motor, this seal is easily able to be replaced and is inexpensive right from GM. You can remove you wiper blades and the plastic coweling in front of the widshield then look down inside where the intake is for this blower motor and you should see the seal just laying there or maybe hanging off. The purpose of this seal is to divert rain water that runs down the windshield and into this intake area. Replace this seal and it should take care of the issue.
If this isn't the issue some of these cars had an issue with the windshield not having enough adheasive installed on the lower portion of the windshield and allowing rain water to be driven in between the window and the dash, the water then runs down the firewall behind the dash and corrodes wiring. A friend of mine had this issue on his pontiac and had to had the entire ECM wiring replaced and the window resealed.
Dec 30, 2011 | 2004 Pontiac Grand Prix
Brand new GE room size ac unit (1 week old) is spiiting water out of the air vent into the room. Unit 100% level.
If a brand new unit is spitting water, i waould suggest that it is short of refrigerant... Get your installer back or the Manufacturer.. You need to hold An ARC licence to do this ( In Australia)
Jul 16, 2011 | Heating & Cooling
There is water in the living room floor after the unit runs even for a short time. Where do you locate the stopped up drain. Where would I begin my search?
If your furnace is in the closet or laundry room, the coil that's leaking is either(1) on the top of the furnace if your ductwork is in the ceiling,(2) on the bottom of the furnace if your ductwork is in the floor. The drain that may be stopped up stubs out of the bottom left or right hand corner of the coil box. Sometimes you can flush it out with water but the best way is to find the end of the drain and get a shop vac and stick the shop vac hose on the drain, seal it real good and try pulling the junk out of your drain. Your drain may drain outside somewhere on maybe to a floor drain.
Apr 12, 2011 | Heating & Cooling
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
I would like to solve the problem of droping water from the air conditioning units instaled outside windows of my apartment. To avoid this problem a canalization should be mounted up to down of the...
in our school building, there are 2 air con. units per room.. we also have 3 floors which has approximately 30 rooms per floor.. what i observed is that they put a hose from where a basin-like is installed so that when water leaks, it goes to the basin just under it then through the hose down straight to a canal.. besides, a hose is extendable, there are no limits which is why it's good for buildings too.
Jul 08, 2009 | Sunbeam Health at Home Waterless Vaporizer...
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe?
Check the A/C condensate drain tube, which is under the glove box, towards the center console, going thru the firewall. If it is plugged, the water in the A/C box will have no place to go & leak onto the floor. This is a common issue, and running the A/C on the "fresh" mode compounds this problem. When the A/C is on, the water removed from the interior is supposed to drain out thru the firewall onto the street.
Aug 04, 2008 | 2002 Toyota Camry
Water pools next to air conditioner
Air conditioners and high-efficiency combustion furnaces create significant condensation, which exits through a plastic drain tube. This should go into a floor drain or be carried away by a small "condensate pump." If water is pooling at the base of the appliance, something may be blocking the water's flow or leaking, or the pump may not be working. 1) Look to see if one of the tubes is leaking. If it is, replace it. 2) Test the condensate pump by pouring water into its pan. If the pump doesn't start, either it isn't receiving power, or it is broken. Be sure that it's plugged in and test the circuit. If it's broken, either get it repaired or replace it. 3) If the pump runs but doesn't empty the pan, the ball-like check valve just before the discharge tube is probably stuck. Unscrew the check valve and loosen the ball inside it. Look for an obstruction. If it appears that a condensation drain tube is clogged with algae, remove it if possible (you may have to cut it and replace it later with a coupling). Run a wire through it to clear it. To kill algae, pour a dilute solution of bleach (1 part bleach to 16 parts water) through the pipe. 4) With an air conditioner, ice may be blocking the tube. If this is the case, be sure the filter isn't dirty. If the filter appears to be fine, the air conditioner's refrigerant supply is probably low. This is when it's time to call an air conditioning technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
