Question about Hitachi 57SWX20B 57" Rear Projection Television
Went from great picture to black after a couple of flickers. Sound Great.
The picture was fine, it flickered a couple of times, went black came back on then flickered again and went black. I turned it off and back on, it came on momentarily, still a good picture then went black again. The sound is fine. I had a TV repair guy come out and I don't think he had a clue. He didn't bring any diagnostic equipment in the house. He decided the (from the rear of the set) left section the the circuit board needed replacing, he took mine brought another, it made no difference. Then he took the mid section of the board and returned, still no difference. On his 3rd trip he brought in his multimeter and checked the high voltage power source. He said it was only something like 20 volts (?) and said it should be 60,000. He said he couldn't get another but he would rebuild. He came back in stalled and I heard a pop. No picture but still sound. My set was purchased 6/03 and used less than 3 months out of each year since purchased. I cannot find any repair services in the yellow pages. Any suggestions? Many Thanks Lou
  • 4,402 Answers
That would be the flyback could also check in this area
Posted on Dec 05, 2007
Hi. I have a toshiba regza 32wlt68 The green light is on the panel but the screen went black. Did have sound, switched off to red light. Then back on, green light on but screen still black, no flickering,...
Main board fault.
Shorted component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 05, 2014 | Televison & Video
Plasma television screen flickering
y-sustain board possibly faulty
Jan 12, 2013 | Televison & Video
Used to flicker, now dead
You possibly need to replace either the Main board, or the power board, they both can be purchased online, and you can either install yourself or go to a site like and accept bids.
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
PS3 does not work in 1080p
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
Color flickers on and off
I went to the Sony support page for your model.(link below)
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
Philips 37pf7320a/37 picture issues.
control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
Sep 20, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Screen seems to dim and there is flickering while watching
This is both a common and fairly easy repair in this unit. Remove the back, but not all of the back needs to be removed to access the power supply area and locate the power supply board. You might find that all three E919,E920,E921 of the 35v/680uf caps in the upper left of the PS board are bowed and/or vented. Replace all three of them even if they test good...
Next, esr the remaining caps. Last one we did here in the shop there were 16 total that we replaced, many were orange in color but I don't have any notes on their value. The orange color of the cap is a lesser temp range we used 105 degree or better as replacements. Some we used a higher rated cap (higher voltage) same uf rating. Gave it a greater reliability.
Good Luck!
Apr 08, 2008 | Insignia IS-LCDTV32 32 in. Television
The problem is the small signal board that is the video processor.
Mar 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Hitachi 57SWX20B 57" Rear Projection Television Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
