Question about Frigidaire ATF6000ES Front Load Washer
Seal around door molds and clothes smell musty. can these be replace at no cost?
  • 31 Answers
Door seals are upto a 50 spot some are a swine to o but some a easy you can buy them but tate a good look at yours befor you take it off and rember how it gose back on. leave your self a few hours to do he job so you are not rushing
Posted on Jun 26, 2009
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
How do I get rid of musty smell from my Frigidaire front load washer?
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump.
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaks water under unit and smells musty model# mah6500aww door boot was replaced and still looks fine doesnt allways leak just when it wants too also cloths smell like river water and sometimes still has...
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 07, 2009 | Maytag Neptune Washer
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
The seal around the door molds. And my clothes
Just send me your $19.95 and I'll share my secret with you!!!
Jun 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty smell in washer and clothes.water remains in rubber gasket
Two thing that you might try: Add two or three cups of bleach and have the machine run a cycle (with no clothes!!!). Second, always leave the door open after use to let it air out. Also, it wouldn't hurt to use straight bleach as a wipe to the entire rubber tub seal.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Mar 18, 2009 | LG WM-2277HW Front Load Washer
The bin stinks like mold
Have had machine for 6 years.  Mold is an issue.  Occatioinally I clean out the drawer and behind the grey rubber seal with vinegar.  After a load is washed, I dry off seal and leave door slightly open.  Occationally I also wash a load of nothing but bleach.   Hope this helps.
Dec 30, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
