Question about Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo
Water continues to drip into overflow tube after fill
Gmax floating system by toto
  • 224 Answers
This is normal, though not so if it is excessive. Try adjusting the fill valve (there is either a ballcock or a float that surrounds the fill valve). With the ballcock, there is a screw at the top of the fill valve to lower the arm, on the other there is a metal clip to pinch and move the float with a large plastic screw for fine tuning.
Posted on Jul 05, 2009
Toilet Problems: One has Noisy flush & two others drip at rate of about two drips per second
Do you have a way to check your water pressure each of these problems could be caused by excessive pressure you may need to install pressure adjustment valve if you can't find another way
Jun 10, 2017 | Toto Home
THE WATER KEEPS FILLING PAST THE OVERFLOW.
Replace fill valve. Fluidmaster works quite well and is very adjustable.
Jan 21, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Water drips into overflow valve after flushing
The purpose of the "Overflow" tube is to fill the toilet bowl. It should drip for a while. If it is continuously dripping there could be dirt or deposits on the ball **** valve. Shut off the water and dissasemble to see if there is deposits or perhaps a torn diaphragm.
Oct 15, 2009 | Toto Promenade, 1.6 GPF, Elongated...
New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Sep 14, 2009 | Toto Washlet S400 for Power Gravity...
My Toto keeps running
Yes, there is either a screw that can be turned lowering or raising the water level, usually found on top of the fill valve.
Or there is a lever system that raises or lowers the float, thereby raising and lowering the water level.
The first it typically found on fill valves with a float ball attatched by a metal rod to the top of the fill valve.
The second are on the "fluidmaster" type fill valves.
If you still cannot find the water level adjustment describe in detail or provide pictures of the type of fill valve you have and I will walk you through it.
Aug 16, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto Drake with Gmax that oesn't completely shut off.
When you look in the bowl of the toilet, do you see the water trickling? If so then the flapper needs to be replaced.
Also, does the water run intermitentedly? As in every 2 to 5 minutes does the water kick back on to refil the tank? If yes then the answer is yet again the flapper.
Now if the water is constantly running then you can try bending the float arm (the ron that is connected to the big floating ball) down and see if that helps. If not then the next step is to replace the fill valve assembly.
Both of these together will run you about $20-$30.
Apr 29, 2009 | Toto Drake ADA Compliant Toilet with...
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
Toto GMax Flushing System drips
What you are experiencing is a flapper valve problem. Since I don't know what model you have I will give you a link to the generic GMax unit. Here is the parts breakdown for a GMax
Toto GMax
I would suspect you need part #7 on this diagram a flapper valve. Take the old one with you since different colors ones are used on different models. You should go to the Toto site to locate a dealer first. You can find their site here:
Toto USA
Hope this helps and please remember to rate this!
Dec 07, 2008 | Toto Home
Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo Logo
1,043 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
