Question about Black & Decker String Trimmer Cordless 12" 18V
Older 12" string trimmer - restring won't feed
My Black and Decker string trimmer is older, requires an electrical cord. The spool is up near the handle at the top and feeds through it, is exposed along the extension down to the actual trimmer. You feed it in by hand and it usually comes right out the trimmer area underneath. For some reason it is stuck. There is a button near the bottom that says "groom" or "edge" with arrows. I have never used that button but wonder if it is part of the problem. I have re-strung it before, but this time its stuck! I do not want to take it apart (screws etc) unless absolutely necessary. Any thoughts?
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
  • 64 Answers
SOURCE: Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Posted on Aug 07, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: Black and Decker gh1000 type 2 string trimmer the
I had the same problem, there is another screw hidden under the black sticker. If you feel around, there is a soft spot. That's it.
Posted on Jun 02, 2010
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
How do I change the cord on a type 3 trimmer
You can buuy spools already wound with string or restring the spool you have. When you look at the head you should see two orange buttons, press them and lift the cover off the spool sits inside. Replace with a new one or restrung one running the end out the hole. Replace cover and you are ready to go.
Sep 01, 2010 | Black & Decker String Trimmer Cordless 12"...
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
How do you restring?
some string trimmer had a arrow direction. ethier in the cap or the spool itself
Apr 22, 2008 | Black & Decker String Trimmer Cordless 12"...
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
