Question about Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50 - TV comes on then goes to a black screen - sound is fine. In the 2 or 3 mins of TV visual time, the color looks a bit off - lacking red - could this be a bulb problem? Bulb does not look blown.
  • scatanzaro Jun 27, 2009
    Thank you, I'll buy a new bulb.
  • 10,594 Answers
Hi
Its symptom of weak lamp so TV needs new lamp.
Lamp replacement procedure is written in user manual and lamp part number is as follows..
F93087600 Lamp Block XL-5100
Available in Sony Accessories Store, please buy Sony Original Lamp for TV safety.
Posted on Jun 26, 2009
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega kdfe55a20 screen goes black, no sound
You can pull the lamp and have a look at it. I have a tutorial on these lamps if your interested. It has a bit of detailed explanation of how it works and how you can identify damage. To view it, look at my Tips & Tricks "Kitchen Table Investigation, Projection...". I hope this was helpful.
Mar 30, 2010 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
May 20, 2009 | Hitachi 65F59 65" HDTV
Screen goes off black...
your console might be over heated . if you continusly try to play it, stop leave it alone for around 10 minutes. get a soda watch some tv and make sure that consule is completly disconnect from the wall.
Jan 17, 2009 | Sony PlayStation 2 (PS2) Console
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
I have a 1993 Sony Trinitron 32" TV, mod.# KU32TS46. It started with the screen going black but sound still working every 30 mins for 3mins and then it would come back on and work fine. Now it works...
This could be as simple as bad connections on the main board or the beginning of the CRT failing. Try opening up the set and carefully turning the screen control clockwise just a bit. This control shuold be the top knob on the flyback transformer (part with large red wire coming out the top). If that "fixes" the problem, then your CRT is starting to fail and you just bought time to get a new set. If that does not fix it, try looking for poor solder connections on the board.
Keep us posted.
Dan
Apr 15, 2008 | Televison & Video
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
188 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
