Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Flashes ER on front and rinse only will not reset
I've tried unplugging, hitting all the buttons, running it through a cycle. This was just purchased in April 2008.
  • bcinnewmexic Jun 26, 2009
    This is a dishwasher - not a stove. Change the input? On a dishwasher? I don't understand
  • 854 Answers
Shut the power off for 30 mins at circuit breaker and then it worked after that.
Posted on Jun 27, 2009
    Sergeant:
    Champion:
  • 233 Answers
Change the input. It' on VIDEO and it's looking for a video input device, like a DVD player or VCR.
Hope this helps!!!
Posted on Jun 26, 2009
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
I have a frigidaire wall oven which was on bake accidently hit clean and immediately hit cancel. Sounds like fan running and started beeping and F8 appeared. Turned off breaker and turned back on same
Hello - Typically error code F8 indicates that there is a communication error between the user interface and the control board. Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 23, 2012 | Ovens
White westinghouse oven stove door has locked and cannot open
Hello there and thank you for choosing fixya
when this type of error occurs the thing to remeber is that these ovens have a internal reset feature on it and when the door locks like this you need to reset it this is done by first unplugging the oven and leaving it for 1 hour minimum WITHOUT TOUCHING IT then when the hour is over plug in the oven and you may hear a audiable beep if so great ***note sometimes this beep will occure within 5 minutes of the oven being plugged back in so you may have to wait for it ok but if it doesent happen simply press the cancel button and unlock the door as you would normally would ok***
If this doesnot solve the problem you will have to manually open the door this is done by removing the lower drawer up where the door latch is there is a release tab that has to be tripped in order for the door to open ok if you can get your arm up in there you can trip it from there
Mar 07, 2011 | Ovens
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
Self clean
Usually the oven has to be locked closed with a handle on on the front door. This will activate a safety mechanism that will allow the cleaning cycle to start. If the safety switch is malfunctioning or the door is not closed properly, the cleaning cycle won't start.
Apr 20, 2008 | Ovens
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
50 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
