I have a wall air conditioner and now it is leaking,what i guess is water through the front. can any body tell me what to do it had never done this before this year.
  • 66 Answers
The unit may need to be cleaned. There is a temperature actuated plug that opens, it may be clogged or not working right
Posted on Jun 30, 2009
Thru the wall air conditioner is leaking droplets of water from between the frame and the body
Your unit should be pulled from the wall and cleaned. Also Check with a level that through the wall sleeve that the unit sits in has a slight lean towards the outside and not inside.
Jul 05, 2011 | Friedrich Heating & Cooling
THE AIR CONDITIONER LEAKS WATER FROM THE FRONT OF THE UNIT.
Look for the drain line coming out of the unit typically in the bottom. Clear out this drain line with a vacuum or water hose. It should begin to drain and stop leaking.
If the leaking continues, you may have a cracked drain pan or severe drain blockage.
Jul 31, 2010 | LG Goldstar GWHD5000 wall/window Air...
Wall unit leaking water new installationseems to be drain line problem.
I had this problem once. I took the front cover off the wall unit and located the the drainage hose and found a build up of dust which was blocking the outlet.
Jun 17, 2010 | Fujitsu 18C1 Air Conditioner
HOME AIR CONDITIONER LEAKING WATER
your drain lines are backed up and you either have no safety devices or they are not operating properly.
Shut the system down and clear out all your drain lines. If your system has no float switches installed anywhere, then you need to have this done to prevent any more issues.
Jan 18, 2010 | Carrier 38CKC042 Air Conditioner
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Nov 09, 2008 | Maytag M7Y15F2A Air Conditioner
Air Conditioner leaking water
there is a drain that comes out the wall to the outside find it and **** it out with a good wet dry shop vac.
Oct 19, 2008 | Sanyo 09KHS51 Ductless Mini Split Air...
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
