Question about Lowrance LMS-332C GPS Receiver
My LMS-332C receiver will not pull-up the NMEA2000 under the menu button, I was trying to check out the software version of my module LGC-3000
2 Suggested Answers
jjanssen7
  • 6 Answers
SOURCE: my lms 332c comes on by itself and flashes.now i
Power switch is stuck on. It is a tricky repair, but disable the swtich internally and install one externally
Posted on May 28, 2010
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
Our unit will not power up
Hi urcvrdha,
You have an elaborate unit! I like these. Your problem sounds more electrical than software related. Try taking all power off the unit for about 30 minutes, then powering up again. Of course, check your fuses. If you get the unit back up to the main menu, and things are not working properly, go to the various "reset" options in your manual for that mode of operation.
If it does not succeed in getting power, I recommend contacting your local Marine/Lorrance dealer for service.
If you don't have your manual handy, download one here:
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS-337CDF_0156-071_121704.pdf
I hope this adds a little information to your problem search. Thanks.
Regards, Bill
Sep 16, 2010 | Lowrance LMS-332C GPS Receiver
My lms 332c comes on by itself and flashes.now i
May 17, 2010 | Lowrance LMS-332C GPS Receiver
Oftern cannot secure GPS location. Unit works on
Press the Exit button. You can toggle between what you are looking at and your present location just by pressing the exit button. I have a HDS5, and that is how it works. Spent a year trying to figure it out. It was that simple.
Apr 02, 2010 | Lowrance LMS-332C GPS Receiver
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
I need CD, or DVD to learn how to use my Lowrance it is modle LMA-332C & LMS-337C DF.
Here you can buy the DVD for $13:
Bennett Training DVD For Lowrance LMS-332C
Here is the user manual:
LMS-332C and LMS-337C DF Owners Manual
Do not forget to rate the solution appropriately.
Many thanks.
Aug 31, 2008 | Office Equipment & Supplies
I have a lowrance lms332c and the unit powered off , was able to restart.shortly after powered off again and now has nothing.checked fuse and fuse is ok.
try to hold in the page button and power button at the same time to reboot your unit, But you may or may not lose waypoints,
Jul 11, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Lowrance LMS-332C GPS Receiver Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
