Unit will not work it will turn on if i go to test mode that it it,my humidity in basement is 96%
  • 2,200 Answers
Can you clarify what is the make and model of the aircon system?
Does it have a readout showing up any trouble codes?
Thanks
Posted on Jun 26, 2009
Whirlpool AD70USR0 Dehumidfier - Our basement is extremely humid and the dehumidfier sounds and looks like its running but collects no humidity...any suggestions why?
If it is very cold some of these consumer units will not turn on the compressor. If the unit suddenly stopped working and the temperature is room temperature I would guess a refrigeration issue- either a leak or bad compressor. Make sure the "full bucket" indicator light is not on- the condensate bin may not be plugged into the unit properly.
Sep 25, 2011 | Whirlpool Dehumidifiers
I have an LG model LHD65EBL dehumidifier. The humidistat will not change from 70 when I push either + or -. The fan runs well and the compressor sounds like it is running well Some water comes out when the...
Prt of the problem may be a dirty or clogged air intake filter.
Turn the unit OFF and unplug, it before removing the filter to check and clean it.
You can ether vacuum it or if it's really dirty & clogged, wash it in warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow it to dry completely, before reinstalling it.
Never operate the unit without the filter in place. As this could damage the unit.
Plug the unit back in and turn it ON. Try lowering the humidity extraction level now, using the arrow down button. For a very damp, humid basement application 35% is a good setting to start with for several days.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | LG LHD65EBL Dehumidifier
Dehumid....ad70usso....runs all the time auto settings don't seem to working collects fine ..but won't turn off when air is dry thanks
There are 4 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. Also, keep in mind, basements stay moister longer than upper rooms.
1. The humidity extraction level is set to HIGH. Lower it to 32-35% and disable the auto mode.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Jul 14, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
A friend let us borrow hers she used it once and we used it last summer in our basement, this year my son turned it on andit just gothot after several hrs but no water. so we have it in the bathroom with...
Kate, There are several basic things that can cuse the problem you seem to be having. At least you're doing the steamy bathroom test. You must have read one of my relies to someone else.Keep in mind, the lower the humidity extraction percentage or number, the more humidity it will take out of the air.
1. The air intake filter is dirty or clogged.
2. The humidity extraction level is set to HIGH. Lower it to 32%.
3. Obstructed air flow around the unit. You must maintain a minimum of 12" clear air space around the entire unit, while in operation.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. This is true in basement applications and the unit will not function properly. Unless it's a Low Temperature unit. Placing it up off the floor on a sturdy table or counter top that can adequately hold the weight of the unit, plus a full bucket of water, usually solves that problem.
Worse case scenario, the compressor needs to be recharged with refrigerant gas (R14). But, that doesn't happen that often.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 11, 2011 | Haier Dehumidifiers
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
Plug it in turn it on and nothing in the bucket after several hours
Hi, Mindy! The following is an overall review of what causes the problem you listed.
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water. In addition, if you set the humidity level you want to maintain higher the actual humidity level in the house or room, it won't pickup and collect any moisture. The fans on most of the dehumidifiers on the market today run almost constantly. They do this, so that the room air is always moving and if humidity is detected, it will extract it.
Hope this helps you understand how dehumidifiers function and what you can expect from them under given circumstances,. In fact, there may not be anything mechanically wrong with yours. But, to make sure, do what is suggested above to test the unit.
Apr 29, 2011 | Haier Dehumidifiers
Have a wind chaser wdh running in my basement and it keeps icing
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Have Whirlpool AD50USS - unit ran for over 24 hours in DRY mode but collected no water. Should have been water in bucket as basement smells musty.
Dec 28, 2009 | Whirlpool Dehumidifiers
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
