Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
14 hp briggs runs fuel filter dry every 15 minutes. have to blow into fuel tank to fill filter up then it runs for a while again. whats up ?
  • Craig Butler
    Craig Butler May 11, 2010
    Bad fuel pump or sucking air.
  • Christopher Keene May 11, 2010
    sounds like trash in the tank is blocking outlet.suggest you remove and flush tank and check outlet port for good flow where hose connects.
  • 434 Answers
Sounds like the tank is not venting. Try leaving the cap a little loose and see if it stays running. If it does, either the vent for the tank or a vented gas cap is plugged
Posted on Jul 01, 2009
    Problem Solver:
  • 12 Answers
I had the same problem its trash in your tanks or line.clean tank and line good.it fixed my problem.
Posted on Jul 07, 2009
14HP B&S on mower tractor. Sputters off when it gets hot. Will start again after it cools. Checked fuel for vapor lock, but it has fuel. Check coil flywheel gap but it is good. Me thinks now it might be valves or linkeage as engine appears to turn much faster whith the starter motor when it is hot. Any ideas
Posted on Jul 06, 2009
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
21 hp briggs and stratton run for about 15 minutes then shuts down then i see the fuel filter is empty
Check out the small fuel pump vacuume located between the fuel tank, engine, and hose to the carb. You may need that part because the same thing happened to my brothers mower.
Oct 01, 2012 | Measuring Tools & Sensors
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Mower engine cuts out at exactly 1/2 full tank of gas
When that happens loosen the fuel cap and see if it stays running. If this is a gravity feed system make sure you have the correct fuel filter on it,the clear paper filters can allow vapor lock to happen,put the small briggs and stratton filter in it,which has a small chamber and a stainless screen.Also make sure there is no excess fuel line that would cause a dip or a high spot for a vapor lock to occur.
Aug 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Having problem starting and keeping engine running. Spray engine starter fluid and runs for couple of minutes then dies. Acts as if its not getting fuel. It is a 13.5 briggs and stratton engine. Could it...
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Runs for awhile then will quit
Have the fuel lines or engine shielding been modified at all? Has the fuel filter been changed?
If all of that is OK, remove the fuel line from the tank at the fuel pump, remove the fuel fill cap, gently blow air back through the fuel line so you can here bubbles in the tank. The "tank pre-filter" could be plugged.
Let me know.
Regards,
May 14, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
677 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
