Question about Husqvarna Garden
Hard to start when cold starts one pull when warm
    Problem Solver:
  • 8 Answers
Hehehe. It's a "husky". The problem is not uncommon even with Husky motorcycles. Some things to check are: Correct sparkplug; correct gap; no carbon buildup: Correct gas/oil ratio mixture, old gas is a NO: Weak or stiff carburetor diaphram. Maybe this will help. I sold mine and a friend sold his because of this specific problem. I also sold my race winning Husky "trials" motorcycle because of this aggrevation.
Posted on Jun 26, 2009
Why is Husqvarna 430 ls hard to cold start?
I COULD BE SET A LITTLE LEAN ON THE HIGH SIDE THIS IS MOST LIKELY THE CAUSE.HELP FACTERY MEET EPA GUIDE LINES IF UNDERWARRENTY CAN NOT TOUCH IT,BUT IF OU OF WARRENTY FIND A GOOD SAW MAN IN 15 MINS HEOR SHE CAN HAVE THIS PROBLEM RESOLVED.STEVE HUTCHINS
Aug 12, 2014 | Garden
5.9 cummins will start fine when cold when warm is hard to start but will start within 5 feet with a pull what could wrong with it
The starter could have wornout bearings that alow is to spin when cold but when things get hot they expand and cause drag reducing the RPM to a point where it wont start.
Oct 21, 2013 | Cummins 5.9 Engine
Hard starting when cold
Have you checked base fuel pressure with a gauge before and after cranking the engine ?
Jun 17, 2013 | 1996 Chevrolet Cavalier
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
Hard starting, rough idle when cold, then smooth running when warm
Need year/make/model/mileage of vehicle to provide a more specific set of troubleshooting steps.
When was the last tune up? Hard starts when cold are usually caused by fouled spark plugs, worn plug wires, or weak ignition coils. Fuel systems are not as effected by temperature changes as the ignition components.
Nov 28, 2012 | Cars & Trucks
1998 gmc sonoma 2.2L when motor is warm it is hard to start-floods- start good when cold
Check the fuel pressure regulator. Pull the vac line after it is warm and see if it is leaking gas into the vac line.
Dec 28, 2010 | 1998 GMC Sonoma
Zl 600 1986 is hard starting
Ok, the correct proceedure for starting a cold engine is as follows, pull the choke fully on, and crank over the engine, DO NOT use the throttle when cranking the engine, when the bike fires and starts, slowly turn down the choke until a smooth fast idle achieved. The important thing to remember is, do not use the throttle while the choke is on, as this lets it **** in cold air, and makes for a harder start, remember the choke is there to restrict air flow, make a rich fuel mixture, for cold starting. If that does not work, then mabey u have a carby problem, make sure your choke is coming on.
Jun 01, 2010 | 1986 kawasaki ZL 900 A2 Eliminator
93'Saturn engine problem:
engine coolant temp sensor is most likely cracked.. I know it sounds strange but pull it if your looking at the engine it is on the right side of the head Will make the car hard to start, smoke, and the idle will often race up and down.. easy to fix 15 dollars or so..
Jan 07, 2009 | 1993 Saturn SC2
Hard to start in the cold
I believe it's your Throttle Position Sensor.
Dec 22, 2008 | 1995 Pontiac Firebird
Garden Logo
106 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
