Question about Refrigerators
My belling fridge has a 1 to 7 temp setting , which is low and which high temp ?
  • 286 Answers
Normally the smaller number is the warmer setting and the higher number is the colder
Posted on Jun 28, 2009
Viking fridge top and bottom model#vcbb536rss is beeping sporadically, the display screen is flashing, what is wrong with that? what part we need to check?
high low voltage board were likely not needed
board registers high temp and after a few days of constant high temp alarm will restart
by replacing low volt board all you did is start with empty register also when replacing low volt board they have to be programed for your model
sounds like you need service for your cooling issue
May 31, 2017 | Viking Refrigerators
My fridge keeps freezing how do i change the temp settings
Hi!!
You didn't mentioned brand and model of your fridge, so I will give you a general answer.
Usually the controls are in the fridge compartment, either on the right or back upper wall. Usually is one control for the freezer and another for the fridge. The normal settings should be about 1/3 of the dial's range, ie. If dial have 9 numbers, the setting should be between 3 and 4, depending on use and outside temp.
Wait 24 hrs. between adjustments to allow the system to stabilize.
.NOTE:
The Freezer Temp. Dial is the main temp. controller, if you set it too low, it may not have time to cool fridge side properly.
Good Luck!! Don't forget to rate this post!!!
Aug 03, 2010 | Refrigerators
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
When setting fridge temperatures is low cool best?
high and low relate to the speed at which the unit will reach operating temp..low saves energy.high is for newly stored food.
Mar 10, 2010 | Refrigerators
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
I have a GE side by side GS25LGM. The fridge side gets too cold that it freezes the vegetables. There is a humidity control on the vegetable bin. It didn't matter if I set it to high or low it still...
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerators Logo
649 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
