Question about Brother ML-300 Typewriter
How do I reset the margins for bigger paper?
I am trying to type on paper that is wider than 8.5. I need to be able to reset my margins but cannot figure out how.
Please help!
Thanks for your time.
  • 125 Answers
Hi:
Most of these small portable typewriters have dual function keys. You need to find the keytop that has Margin Release on it. It might say Mar Rel. If this in in a color that is different then what ever else is on the key then this is a daul function key. What this means is that you also have to look for a code or mode key. Once you find that hold that key down while pressing the Mar Rel key once. Then release both keys and use the backspace key to back up through where your left margin is currently set. Once you have done that you can reset the left margin at that point by findind and pressing the Left Margin key. Note that the left margin key might also be a dual function key.
You can extend the right margin by spacing to it and then doing the same procedure above , but this time release the right margin and space throught it and then reset it where you want it.
Good Luck
Andrew
Posted on Jun 26, 2009
How do I make the margin wider to where the comb binding holes punch
Adjust your text in your word processor,. WORD?
Look up File - Page Setup - Margins
Oct 02, 2015 | Office Equipment & Supplies
How do I increase the area where I type?
You should have a "margin " adjustment on the typewriter. Just narrow the current margin
Sep 10, 2014 | Olympia Startype 3 Typewriter
Why won't the printer print .5" margin on the side
1. The side guides of the paper tray are adjustable and should be snug to the edges of the paper. To loose and things can begin to shift.
2. Are you using letter sized paper or A4. Your print driver and word processing program need to know this.
3. The driver and processing program have margin adjustments within them. They are usually good by default but perhaps another user was in there and changed things.
4. Is the print job specked for the correct orientation....portrait or landscape and is the paper loaded the same.
Jul 25, 2014 | HP Office Equipment & Supplies
ComDear all, Please help to solve thia problem: print revoew does not match print out (the margin of the paper)
Hi
The default margin settings are not the same for the right and left hand side of the page.
The left margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007, for example:
Page Layout > Margins > Mirrored Margins.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 05, 2011 | HP LaserJet P2015 Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
Adjust the margin settings manually. In MS Office 2007:
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
How do I adjust margins on Smith Corona WordSmith 100?
Return to the L. margin Press code and 1 release kets backspace to where you want L. margin press L mar key.
DickyO
Jan 06, 2009 | Smith Corona Wordsmith 100 Typewriter
Problem with konica minolta paper margin
You don't have any solution but to increase the above margin to be equal as the bottom margin. To successfully print the pages, this printer need a larger bottom margin compared with the above margin. Just use the 'Center on page' option from your graphic application.
Jul 18, 2008 | Konica Minolta magicolor 2500 Printer
Margins not recognised
Hi lerona - I have a 5600C series HP printer. You might try these tips:
Do a Print Preview to be sure the document looks right on your screen, then in Print Setup, down in the Zoom box check the Scale to Paper Size to be sure it isn't set for the wrong paper size. There's an arrow to scroll to the size you're printing on.
Then click Properties, then the Paper Quality tab. There's an item that says "minimize margins". You could try printing with the box checked (if it's not now), or unchecked (if it IS now) and see the difference. Click the Effects tab and be sure the "normal size" box says 100%, and that there's no check mark in the "borderless printing" box.
I print documents all the time, as well as photos, smaller sized items, cards, etc., and have had no trouble with the margins printing differently than my Print Preview shows on my screen. I hope these tips help you. Good luck, and feel free to email me if you have any success with my suggestions.
Jo
JokerGirl524@aol.com
Oct 28, 2007 | HP DeskJet 5150 InkJet Printer
Brother ML-300 Typewriter Logo
276 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
