Question about Garden
Briggs & stratton lawnmower engine
How do i time the engine Took it apart and forgot to check what go`s where. Appreciate all the help i can get...... THANKS
  • liam_kelly51 Jun 27, 2009
    had already done that. Moved it around full circle. still wont fire up. thanks for your help.
  • 181 Answers
On the crank gear there is a circle punched in one of the teeth.then the cam gear has a punch mark between two of the teeth.those two marks must thouch each other.the tooth on the crank will be in between the two cam gear teeth.then the air gap between the flywheel and the magnito is 0.012" .....................hope this helps,let me know
Posted on Jun 26, 2009
  • steve
    steve Jun 29, 2009
    how is the fly wheel key.sometimes when putting the flywheel on they have been known to brake.may i ask why was it taken apart for? please let me know and i'll try to help you out...................
I need help locating a part number for an oldeer briggs & stratton lawnmower motor
Try at Find Replacement Repair Parts for Briggs Stratton Engines
input your model number under Find Parts by Model and select the next three steps to get a detailed exploded view and part codes with prices
Mar 28, 2016 | Miscellaneous
Briggs and stratton lawnmower timing
It would help to know the model number of the engine BUT the timing is controlled by the flywheel. If there is an issue it is usually because the flywheel has slipped and lost alignment with the shaft. Check the woodruff key and see if it is straight.
Jul 31, 2014 | Garden
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
17.5 hp Briggs & Strattion has no spark
unplug the harness to the engine should be a 5-6 wire give or take then crank it look for spark if you get spark that way check the safety switches if no spark change the coil
Apr 24, 2012 | Briggs & Stratton Briggs Stratton...
Illastrated picture of 6.75 briggs and statton lawnmower engine to identify parts
go online to briggs and find there parts manual for that engine and print it
Dec 07, 2011 | Briggs & Stratton Briggs Stratton...
Need repair manual for briggs and stratton 4.5 hp on bolen lawn mower model 11a-414e765
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
May 10, 2011 | Briggs & Stratton Briggs Stratton...
The lawnmower wouldnt stay running so my husband took it apart. He found what was wrong but now he can't put it back together because he's unfamiliar with the no choke no prime motor. There is a long odd...
If the machine is indeed a Briggs & Stratton, then you can go here to their website, put in the model # of the engine it has and get an illustrated parts diagram breakdown. Very useful and quite helpful. Go to:
http://tinyurl.com/3928l5u
Please vote on this solution.
Sep 06, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Need pamphlet for Briggs,Stratton Eastern Lawnmower 2007 Took lawnmower apart, cannot find book on how to put it back together.
You must have model numbers to get any real help. If you mean you took the motor apart, you could go to www.briggsandstratton.com/ and download a manual.
Find your model number on your motor and enter on web site.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the check valve in the carburetor on a Briggs & Stratton
I believe you have to remove the primer bulb and it is located behind it. Be careful and do not damage the keeper or the primer bulb there is a couple of notches on keeper to depress to remove,
Sep 20, 2017 | Craftsman Garden
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
