Question about Mtd Garden
Rear wheels wont turn - Mtd Garden
  • 127 Answers
Replace the flywheel key on the trans axle where the pulley is attached it has sheared off
Posted on Jun 26, 2009
Toro ss4235 wont go into gear nor bypass valves wont take it out of gear
try forcing the wheel to move get the ztr rear off the ground and try turning the wheel if dont but pump sqeeled you have a bad check valve or pump is going out i say bad check vale rebuild it
Sep 03, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Overloaded ERF EC11 and now rear wheels wont turn broken Diff?
possible but if you overloaded the unit I would be checking for a broken axle . Jack up the vehicle and turn the tail shaft to see there are any violent noises indicating a pinion gear/ crown wheel gear failure. remove drain plug to check for metal pieces on magnet
Jan 26, 2014 | Cars & Trucks
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
Rear wheels wont spin
make sure u didn't lose a spacer or that they are in the right locations
Nov 13, 2013 | Yamaha V Star 1100 Classic Motorcycles
My 1997 suburban wont drive but the rear wheels still turn
drive shaft might of snapped or your u joints on the shaft
Feb 28, 2013 | 1997 Chevrolet Suburban
Why is the back wheel solid and wont turn
Either the Brake is stuck in locked position. Check if both rear wheels are locked and won't turn.
Or the Wheel bearing is jammed and needs replacement.
Jan 17, 2013 | 2003 Renault Megane
Renault kangoo rear wheel wont rotate
What year, does it have 4 wheel ABS? If so the ABS hydraulic control valve is most likely leaking pressure to the wheel.
Jul 11, 2012 | Renault Kangoo Cars & Trucks
Rear wheel wont turn
try loosening the nut on the center of the wheel
Dec 18, 2011 | Mongoose Raider Quad Ride-on Bike
I have a 96 isuzu rodeo,3.2 and the brakes will lock up on their own, gradually then it takes about 15 minutes for them to release, any thoughts?
this could be caused by a few things, first you need to jack the truck up you will need all 4 wheels off the ground, put the transmission in neutral and have some one get in the truck and wile turning each wheel have the person in the truck push the brake pedal the wheel should stop instantly then have the person release the brake the brake should release instantly,( do this to each wheel ) if all brakes remain locked ( wont release instantly ) then replace the master cylinder if the both rear brakes wont release instantly replace the brake hose from the frame to the rear differential, if the both front brakes wont release replace master cylinder, if only one front brake wont release open the bleeder on that brake caliper if the wheel releases replace the caliper hose if the brake still wont release with the bleeder open replace the caliper, you should replace the caliper and brake hoses as a pair.
Mar 02, 2011 | 1996 Isuzu Rodeo
Truck has vibration,Rear wheels jacked off up off ground,transmission in park,wheels still turn,driveshaft doesnt.
trucks have a limited slip rear end to help in turning. if both back tires are in the air they will turn,the drive shaft wont turn because its in park. to check the vibration you might check the balance of your tires
Apr 09, 2010 | 2006 Ford Super Duty F 450 Drw
Garden Logo
59 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
